Thunderpole 5 base antenna ?
gmham
Call Sign: 108TM154
Post by gmham »
Thunderpole 5 base antenna, anyone here use one ? It’s the 14 foot type with the ss top whip you cut to size.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
davev8
Re: Thunderpole 5 base antenna ?
Post by davev8 »
Is that the one they claimed is 5/8 wave?....well its not 5/8wave..if you NEED a 14 feet antenna then that's good ,,,but just because it says 5/8 wave on the box don't expect it to behave like one
you cannot electrically shorten an antenna and expect it to work better no matter what wave that they print on the box... its like expecting a car antenna with a coil at 5 or 6 feet long thats claimed to be a 5/8 or 7/8 or whatever to work better than a 9 feet whip..its not going to hapern
I believe the fiberglass 1/2 wave they sell is a similar price at 18 feet it will work better
Mudslinger
Post by Mudslinger »
It would be more accurately described as a 3/8 wave.
Personally I don't really see the point of it.
InTheClouds
Post by InTheClouds »
Literally no point in getting any other antenna than this, almost 1/2 the price and will probably work slightly better.
https://www.radioworld.co.uk/sirio_gps2 ... silver_rod
Thunderpole 5 - 9.9dB gain is 100pct total BS... companies suggesting such figures should be boycotted.
That is a negative gain antenna, if such thing can exist.... read: lossy antenna... think -1dB - it is not even a 1/2 wave if it is 14 feet (it says 18feet in the website but with 9.9dB gain - anything written there cannot be trusted) ! :lol:
InTheClouds
14 feet is a different antenna... it gets worse they call it a 5/8 wave... which would be closer to 6.6m long and it is 4.35m
it's all a load of cobblers.
https://www.thunderpole.co.uk/base-cb-a ... -wave.html
I would still just get the Sirio 1/2 wave GPS.... unless you have heard some wind/storm survival suitability of the Thunderpole which would be the only reason to get one. Otherwise it will be outperformed slightly by the Sirio.
It is time trades description did something about this to be honest.
Post by ch25 »
5/8 wave with 4.35m length buhahahaha
Ground plane also missing
gmham
Call Sign: 108TM154
Post by gmham »
It’s the Thunderpole 5 antenna as opposed to the Thunderpole Galaxy, but yes 14 foot overal height and just won’t tune a low swr enough to cover 28.5 mhz despite the top whip being cut to the suggested size.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
original45
Call Sign: 45
Post by original45 »
Probably well off here as I don't know the antenna personally but After some issues with a mobile and base antenna this may be worth a try.
Had high swr on both wouldn't drop to where I knew it should and a friend with knowledge said add different lengths of coax .I did this tried few different lengths in the end I think It was about 3' well blow me over not only did it drop to 1.1 where I wanted it will now work under 1.2 from 25,600 to over 29 mhz and that's inline with kl 203 3 watts input.
Alinco dx 10 .radios meter and matched same in my separate swr power meter.
Antenna the infamous antron 99.
Worked simular on a sirio mobile antenna too, dropped several needle thicknesses on meter with extra 6" coax.
gmham
Call Sign: 108TM154
Post by gmham »
That’s great, plan is to change location for the vertical anyway so will require a different length of coax anyway so will see what happens. Thanks .
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
original45
Call Sign: 45
Even when moved just try if no better match adding patch leads on and see if changes things
gmham
Call Sign: 108TM154
Post by gmham »
original45 wrote: 25 Aug 2022, 10:13 Even when moved just try if no better match adding patch leads on and see if changes things
Okay thanks strange one as I say thought it would be a lot enough swr going by the cutting chart but as I say 27mhz fine but doesn’t want to play on 10mtrs !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
