Pc-385ag president mckinley help.
Pinksnake
Post by Pinksnake »
Hi guys got a president mckinley here early version.. Main board is pc-385ag...radio has a few niggles I shall try my best to list them...
Driver is 2sc1306 I don't know if this is original.. Output is 2sc1969...when mic gain is up full I get awful gargeled audio through internal speaker on ssb.. And ssb audio sounds awful u till I turn mic gain back a wee bit.
On am as soon as I tx my audio comes out internal. Speaker like a full talk back mod has been done... Sounds shocking..
Rx is fine on all modes just has the described tx issues... Please any help with the afore mentioned issues would b great... Also should the driver b a 2166 instead of the 1306..?
14CS06
Re: Pc-385ag president mckinley help.
Post by 14CS06 »
Hello
Service Manual :arrow:
http://www.cbradio.nl/president/Service ... er_ENG.pdf
TR41>2SC1969>FINAL
TR40>2SC496>BIAS CONTROL
TR39>2SC1306>XMT DRIVER
TR38>2SC1973>XMT PRE DRIVER
Claude
Pinksnake
Post by Pinksnake »
Thanks Claude... I shall have a good look..
lbcomms
Post by lbcomms »
First thing to check would be the microphone - a short inside the plug will cause those symptoms almost as stated.
If you haven't got another mic, remove the outer metal cover of the plug, desolder the receive wire, plug it in and try again.
You'll have no receive, but is the radio now transmitting as it should?
If it doesn't (no change) does the radio receive without the mic plugged in? If so, the short could be inside the radio - could be the mic socket, EXT speaker socket, or the internal speaker itself could be shorted from one side to chassis.
The non standard RF output driver won't cause this, but you may lose a watt or two on SSB compared to the original part.
