Hi everyone, sorry if this has been asked before but here goes.
I have an CRE-8900 on it's way to me and it isn't programmed. My brother has a CRT 6900N with programming cable.
Is it possible to use the 6900N cable to program the CRE-8900?
Obviously it has a different connector, but I seem to remember someone saying that it was possible to remove the cover on the CRE and connect it inside?
Many Thanks
CRE-8900 programming
- Mudslinger
- 14CS06
Re: CRE-8900 programming
- Mudslinger
Thanks Claude, I was aware of the socket, my question was can the other cable be connected inside to save me buying a specific cable.
I am pretty sure that it can.
- Call Sign: Lemmy
You can use any rs232-ttl converter.
I use old Nokia ca42 cable
- Mudslinger
I may have one at home somewhere...
- 14CS06
HelloMudslinger wrote: ↑08 Oct 2021, 09:53 Thanks Claude, I was aware of the socket, my question was can the other cable be connected inside to save me buying a specific cable.
Yes follow the black cable which goes from the rear socket connected to the board
Claude
- Mudslinger
Just to update on this. Inside the CRE-8900 the programming connector is a 4 pin. The one on the 6900N programming cable is a 3 pin.
So in this instance I cannot use the 6900N cable to program the CRE-8900
