ADS-B over Spy Server
MajicM
Post by MajicM »
Hi all
I'm running an Airspy Mini on a Raspberry Pi 400 in a bedroom (soon to be relocated to a loft).
I'm running Spy Server and run SDR Sharp.
In the past (different house, different setup) I had the Airspy dongle plugged into my Windows 10 PC and used RTL-1090 (or similar) to run on a particular port and then feed Virtual Radar.
However, I'm a bit stuck now in this particular setup. How can I do similar now using Spy Server? Is there something I run on the PC which pulls from the Airspy over TCP/IP and then feed Virtual Radar?
Thanks for any help!
