Shogun 40FM
- Otter
- Call Sign: 26TM439
Re: Shogun 40FM
But that's not your address.... I'll probably lose the auction anyhow. I actually have more Shogun selcall units than Shoguns - I wonder if the selcalls are the same pin assignment as Cybernet radios. It could be fun to play.
- Call Sign: 26TM773
Re: Shogun 40FM
So….. was it you who won it lol
- Otter
Re: Shogun 40FM
It was.
Re: Shogun 40FM
Congratulations and thanks.
Fingers crossed for you.
Re: Shogun 40FM
Tim, Tim, he's your man,
If he can't fix it, no one can!
(sung in a cheerleader's way).
- Otter
Re: Shogun 40FM
It was the 7-segment display itself that was faulty. Some segments were completely blown so probably they were shorted to ground at some stage. That's fixed now, so I just have to sort the selcall socket if I'm going to use it. I have the bits for that, so no drama.
Re: Shogun 40FM
Good info Tim, thanks.
Can the displays still be purchased or do they need to come from scrappers?
- Otter
Re: Shogun 40FM
I don't know whether they can be purchased; I just happened to have one
Re: Shogun 40FM
Looks like RS stock a few different types.
Just need to figure out which ones are the correct spec for a couple of other radios I have with missing segments.
