PSU recommendation for TS-590SG
Jim444444
Post by Jim444444 »
So don't fancy forking out 3 or 400 quid for the kenwood psu so looking for some recommendations for a decent replacement. Looking to buy something for around 150 or so.
Re: PSU recommendation for TS-590SG
Post by ch25 »
DPS600PB and 1-2 hours work.
Jim444444
Post by Jim444444 »
Thanks but was looking for something new with no work involved. Out of interest though are server power supplies filtered for HF band usage.
Post by ch25 »
I use 600PB with 7610 since 3 years now. Great, quality PS for peanuts.
Jim444444
Post by Jim444444 »
Nice, do you have any links to show you how to convert it.
Post by ch25 »
cb4ever104
Post by cb4ever104 »
ch25 wrote: 15 Jun 2021, 16:34 http://www.tjinguytech.com/my-projects/HP47A
If you want to raise voltage to 13.8V: https://static.rcgroups.net/forums/atta ... PB%202.jpg
OVP mod: https://obrazki.elektroda.pl/4128460400_1513721548.jpg Lift that led and add 2 silicon diodes in series.
Just bought one of these to mess about with . Only cost a £10 , so pretty cheap .
Post by ch25 »
Hard to beat :)
cb4ever104
ch25 wrote: 22 Jun 2021, 16:24Hard to beat :)
Not sure about the over voltage protection diagram . It's optional anyway . Right ?
Post by ch25 »
Without OVP mod you can raise voltage up to 13.2V
Want more, 2x1n4148 in proper place :)
cb4ever104
The first link states "Putting a 1K ohm pot between 3-9 allows for output voltage adjustment up to 13.8V."
So , is the diode mod necessary ?
Also . Is the diagram you posted right ?
If so , I may need to get some new glasses , as I don't see any leds ... :)
Post by ch25 »
Without OVP mod, when you raise voltage up to 13.8V, under load OVP will trigger and switch off PS. 13.2 is the limit, where OVP don't trigger under load.
cb4ever104
OK . Understood . Is there a better procedure for doing that OVP mod then ? Thanks
Post by ch25 »
It is only method.
Let me explain how it works for better understanding.
OVP chip is measuring output voltage. Unmodded 12V output, when it hits circa 14V OVP trigger and switch off output.
When you raise intentionally output voltage with PR as described (what is fine) almost to the OVP trigger limit you are on the edge.
So you have to raise OVP trigger voltage a little. Adding 2 1n4148 or similar raise OVP trigger point by 1.4V what is completely fine.
Now you can run PS 14V output, full load without issues.
cb4ever104
Hi Chris .
Sorry . Maybe "procedure" wasn't the right word . The photo for me isn't clear . Is there a "before" and "after" photo of the mod that I can use as reference ?
Paul
