magpie autoscan 5000
- Otter
- Call Sign: 26TM439
Re: magpie autoscan 5000
Not a problem. Have a look around that IC7 pin13 though and see if there is a link to remove / place to put a link.
I'd like to have a look at one of those radios, but they don't have enough SSB on them to really interest me. Besides, my radio life seems to be littered with unfinished projects at the moment.
There's currently a spare or repairs Magpie on Fleabay at the mo, ยฃ20 starting price. It's got no working channel indicator neons, but you can use another rig to find out which channel you're on, and you could try the mod on this rig to see if it changes the default start-up channel?????
- Ashtec
- Call Sign: M6LTD
Magpie autoscan 5000 on ebay at the min if any one is after one...............
http://www.ebay.co.uk/itm/Rare-Magpie-C ... 2a16156ef1
4h 13m 56s to go.
4h 13m 56s to go.
- Mudslinger
That is already quite expensive, especially as it is far from a minter.
The box around the channel change buttons is worn off for a start. At least it has its original mic though.
Holy resurrection!!!Otter wrote: โ09 Sep 2010, 21:45I've never seen one of these rigs so I'm guessing.The-General wrote:Old thread that i must dig up,what was the modification that Magpie performed to make the rig goto channel 19 instead of 14 when you turn the rig on? a diode swap or something?? anyone know?? cheers.
Looking at the schematic on CB tricks - look at IC7 and IC8.
The inputs ABCD are preloads. IC8 looks like it does 10s of channels and IC7 looks like 1s.
Looks like IC7 pin 13 should be removed from whatever it's connected to, and connected to ground instead.
Disconnect the wire coming from the Normal/Ch.9 switch where it connects to the board at point 32.
Well, that's my guess. Try it at your risk...
Tim I tried this mod and itโs does start on 19
Only problem is it doesnโt change channels now
DELETE MY ACCOUNT
- Otter
Wow, that was fully 10 years ago and I haven't thought about Autoscans since. It looks wrong to me now I look at it again.
- Otter
OK, put it back to standard. Then:
On IC7 isolate pins 3,4, and 13 from their connections.
Connect pins 3 & 4 to +V on pin 16.
Connect pin 13 to ground which is next door on pin 12.
Spot on Tim ch9 switch is disabled also but thatโs ok by me
As itโs doing what I want now
DELETE MY ACCOUNT
- Otter
I don't understand why channel 9 is disabled, but I'm glad that it does what you want. I should pick up one of these to play with really.
All you need is ch19 nowadays according to most ahem...users, so that would have worked out okay
I looked at the comic book but I couldnโt see why either once Iโd worked out what you said to do
DELETE MY ACCOUNT
