Warrington 455.750
- Call Sign: m3isj
Warrington 455.750
Hi,
i know this may have been asked a number of times, does anyone know the Colour codes for warrington using 455.750
Thanks,
Martin
Thanks,
Martin
Re: Warrington 455.750
Just put the freq in your scanner and it will tell you.
- Call Sign: m3isj
I am useing my dmr radio
If your radio doesn't have a 'promiscuous' mode then try the numbers in turn...it's not as though there are hundreds to choose from....and Dee Communications engineers only seem to have one hand.
- Metradio
- Call Sign: G7HID
Yellow...
Mike
Mike
- Call Sign: mm12
Hi I am not far from warrington whats this freq used for?
- stanogs68
- Call Sign: mm12
Anything please I have been listening to 455.700 but its just white noise! Ill have to read the above listing
Any freq would be appreciated thank you
This was busy yesterday 454.200 fm
- Call Sign: mm12
Hi its an airport
- stanogs68
455 700, Warrington shops and pubs on dmr, 454 200 is more likely hospital voice paging from Alder Hey. Going by the wtr browser, there is nothing in Warrington on 455 750
- Call Sign: mm12
Hi yes on an analogue scanner
most in the area is dmr, very little on nfm. All the shopping centres are dmr. Search from 440 to 470 and 156 to 174, or 183 if it goes that high and let us know what you find. Which scanner do you have?
- Call Sign: mm12
Dated 2019 so apologies
Warrington - Cheshire - (Trunked) - Shopwatch - 455.7000 461.0000
Warrington - Cheshire - Cockhedge Shopping Centre - 456.9500 462.4500
Warrington - Cheshire - Golden Square Shopping Centre - 455.6500 460.9500 (DIGITAL)
Warrington - Cheshire - Golden Square Shopping Centre - 453.2500 459.7500 (DIGITAL)
Warrington - Cheshire - (Warrington Borough Council Communities) - 453.0500 459.5500
Cheshire Fire & Rescue handhelds still on FM, 457.0375
digging around a few sites I have found these and Manchester airport also obviously little due to the covid……
I believe a SDR dongle will receive most of the above
I am on Icom IC R5
I have just looked at RadioShack PRO 96 20 digital trunking scanner the price … you tube walkthroughs
I am on Icom IC R5
