Hi all :-)
My name is Kjell and I'm from Norway, a city called Vadso, far north and east. I used to be shooting skip in the mid 80's - had a HAM International Multimode II back then. Have recently set up a small antenna and will hopefully be online soon (when I get my new CB).
If I can ask then I would like the callsign:
20-TM-618
(618 was the license number I used back in the 80's)
New user from Norway
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: New user from Norway
velkommen til forumet. bra å ha et nytt skandinavisk medlem!
I will allocate your callsign soon, as I am not currently at home, welcome to TM1 and I hope we can make ontact with you in the Spring when conditions pick up a little
26TM175. OP: Craig. QTH: Gateshead. Also 163TM175 when mobile in Wales
- joerstad
- New User
- Call Sign: 20TM618
- MrWeetabix
- Admin
MrWeetabix wrote: ↑06 Dec 2020, 13:48
Hello Kjell, Your number 100% allocated to you and you can start usingit straight away. I hope we can make contact with you as the solar cycle builds again. 73 de Craig
20-TM-618 - Kjell (joerstad) Vadso, North East Norway
viewtopic.php?f=27&t=58484&p=535561#p535561
