Meanwell power supplies question
- Call Sign: Lemmy
Re: Meanwell power supplies question
Far from boom. Output is 14V, OVP set to 15V. Pretty safe.
- Buick Mackane
- Moderator
was a joke lemmy You wrote - 14 volts as in negative 14 volts
- Call Sign: Lemmy
Oh, it was ~ sign, look closer
- Buick Mackane
- Moderator
Your right lemmy, My eyes aren't what they used to be
- gmham
- Call Sign: 108TM154
Was sent this link but chap who sent it says his is not suitable for powering his radio gear due to the noise it creates on his radios, uses it as per the article ..model aircraft charging.
https://www.rchelicopterfun.com/dps-600pb-build.html
CH25...any mods required to reduce / eliminate any noise when using your own mate ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: Lemmy
I didn't notice any noise or birdies from dps600pb on bands I use - 160-6m so there is nothing to reduce.
Important thing when using switching PS - you must use 3 pole power socket, but it's pretty obvious.
- gmham
Okay thanks guess he was just unlucky with the noise issue . Another good read for anyone planning on modding one.
http://vk2rh.com/computer-power-supply/
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: Lemmy
I need glasses, no doubt, but where he complains about noise on the bands? I can't find that.gmham wrote: ↑29 Oct 2020, 22:40Okay thanks guess he was just unlucky with the noise issue . Another good read for anyone planning on modding one.
- gmham
Was talking about the chap who sent me the link in my rchelicopter link who said his was producing severe noise on his radio. But yes the last link I shared certainly never mentioned anything untoward about there use.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: Lemmy
Ok. I din't need to mod mine against RF noise, because I can't hear any.
I have my station located on country side, with very low noise floor so I would notice it.
- Auldgeek
- Call Sign: GM0BRJ
I have a HP power supply that can provide over 100A from its 12v line but it will not provide over +13v without modification, although it's reasonably easy. After modification, mine provides about +13.5v.
A simple resistor bridge bypasses the pull up to start requirement & to raise the voltage, I replaced the voltage VR with a fixed resistor. It's also completely noise free across the spectrum.
Can't get more A for your cash. Spend a wee bit more & put it in a case.
Auldgeek - Drew
- gmham
Hi drew not for sale is it ? Was going to go for one of the ones in the link above mate but just don’t have the tech ability to mod it for the required voltage, lower fan noise etc.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Auldgeek
- Call Sign: GM0BRJ
Unfortunately not but it really isn't difficult & while it's nice to make it look good, it really isn't required. There's a great thread on converting server power supplies in the home brew section & plenty of info on the web.
Auldgeek - Drew
- gmham
Okay thanks drew will see if I can pick one up already converted somewhere.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
