Antenna choice
- Call Sign: ZipMonkey
Antenna choice
Can anyone tell me what is the best antenna for airport/aircraft pickup ?
Re: Antenna choice
A good discone will do the job and plenty of coverage.
Re: Antenna choice
Depends on distance from airport
Sometimes it is a dipole, sometimes multi element Yagi.
Re: Antenna choice
cheers ...can i have both and connect them at the same time to a single scanner ...and can i put a dipole in the loft ?
Re: Antenna choice
Lol, in the loft...
You can put it even in the basement.
Similar results, nada.
- Buick Mackane
Re: Antenna choice
Rubbish lemmy,
I Think you'd find a huge difference between having an antenna in the basement compared to the attic.
Good results can be had from a loft antenna, But its still no substitute for an outside antenna
