Marconi 2955 Help
Hotwire
New User
New User
Call Sign: VA7WPN
Marconi 2955 Help
Post by Hotwire »
Good day all,
I have a fairly well taken care of 2955A. I plan on using it to do test/repair/alignment. But.. I failed to recognize the fact that it does NOT facilitate SSB. I do know there is a work around (1kz up or down for LSB or USB and 0% Modulation). Is there anything else I could or should be doing? Any accessories I should look into (attenuators, or cabling)? Also, the N Connector that usually says 75w max as a sticker on it that says 100w Max. I'v never seen this before, has anyone else?
Thanks a ton
Hotwire
New User
New User
Call Sign: VA7WPN
Re: Marconi 2955 Help
Post by Hotwire »
Here is a photo of the 100W sticker,
I have a radio (set to 10w) connected to the N connector... and I notice a few things.
- First : the SWR is threw the roof
- Second : The 2955 shows only 9mw
- Lastly : When I do a self test, the audio cracles for a few of the tests.
is my 2955 screwed? or am I just not doing things correctly?
df2tb
Call Sign: DF2TB
Post by df2tb »
Did you already have a look into the manual?
Otter
Call Sign: 26TM439
Post by Otter »
I've got to be honest - it doesn't sound good. I have a 2965 (not the 2955) and it's pretty much select the right input, select Tx test, connect radio, transmit and measure power etc.
cb4ever104
Post by cb4ever104 »
It's been a while since I've used one . Don't these have a self test function ?
Hotwire
New User
New User
Call Sign: VA7WPN
Post by Hotwire »
Yes I read the manual.
It displays the right Freq when I tx into it. So it's still passing the signal threw, I'm just wondering if I have configured something wrong.
It does have the self test feature. I will have to look deeper into that.
Metradio
Call Sign: G7HID
Post by Metradio »
Hotwire wrote: 14 Oct 2020, 00:56
Would suspect the cable between the Macaroni and the radio on test...
From memory the audio crackles during Self Test.
Mike
df2tb
Call Sign: DF2TB
Post by df2tb »
May be a daft question but you pressed the blue button labelled TX before starting your measurement?
Andreas DF2TB
Edd200sx
Call Sign: M6KMX
Post by Edd200sx »
They default to Reciver test at switch on.
You select tx function.
If no power meter after that the attenuators blown probably
