How high is my antenna?
- Tigersaw
- Call Sign: GW6RRL
I'm not asking you to be a mind reader, but curious as to what figure you give if asked the question.
Now I give the height of the base (in this case an Antron) which is about 20-25 feet - but this means the tip is 40 feet above ground, so bit of a difference if I was to use that figure.
- Call Sign: Lemmy
Re: How high is my antenna?
You always tell feedpoint height.
Simple example. My 80m vertical is 23 meter high, but feedpoint is 2m over the ground. So my antenna is 2m over the ground, not 25 xD
i always use the length of the mast/pole for anything end-fed, i do the same for starduster & gain-master, my GM is on a 35ft or so scaffold pole about 1 wavelength above a field,
the only cb antenna i have that i don't see that way is the astroplane which is only 1/2 of an antenna as it comes in the box.
W8JI
I've always said that my aerial is *** feet to the tip. As far as I'm aware the whole thing radiates, so if up to the tip does, that's how tall it is.
Plus it sounds much better when you're talking utter sh**e in the pub
- Call Sign: 108SD121
- theEarwigger
- Call Sign: M0RZF
The height of any vertical antenna is the "effective height".
But that's buried in a 100 page antenna book!
... www.M0RZF.co.uk ...
Technically speaking that's correct, effective height is the thing that effects your signals the most,
Effective height is your height of current maxima or centre of radiation where your antenna has the strongest radiation,
for none loaded antennas which covers most cb base antennas,
1/2wave dipoles 1/2wave & 5/8waves end fed antennas, current maxima is 1/4wave down from the tip of the antenna ,
for loaded antennas like hat loaded avanti astroplanes current maxima is at the hub 4ft from the tip, which give them an advantage in height of current maxima or effective height when you are subject to FCC height restrictions,
5/8 gain-master has two current maximas, 1/4wave down from the tip & 1/4wave up from the choke,
height of current maxima is what gives a 5/8wave some gain over a 1/2wave,
but raise an efficient 1/2wave up to same tip height & it has a little more low angle gain than a 5/8wave,
if a local asked how high my antenna was & I replied with "my antennas effective height is 49ft",
they would have no idea I was talking about.
If I say " im running a 1/2wave silver rod on a 40ft pole"
then people who don't understand effective height & current distribution in antennas know how high your antenna is,
& people that do understand current distribution know its effective height is about 9ft higher than that.
W8JI
i should add that effective height effects your antennas gain at low angles the most when the antenna is doing ALL or almost all of the radiating & receiving,
even more so when you don't live in an open field & that extra height of current maxima also gets you over obstructions.
BUT a typical cb antenna install can often have even more of an effect on your signals & local noise than its effective height if you pick or cause by ground wire a low common mode impedance,
and never in a good way
once all antennas are installed correctly isolated at the same tip height many people would surprised even AMAZED as i was myself how little difference there is between any of them including A99's.
a 5/8 waves extra low angle gain vanishes.
W8JI
- andrew013
- Call Sign: 26AT013
i just say my ariel is 24 ft long on a 21 ft pole 35 ft off the ground
- bigpimp347
it's as high as where the coax connects to it..
so if the coax is at 20ft it's 20ft up, 20ft up from the ground.
it's not 36ft up, that's to the tip.
when applying for planning or commercial antennas and such they ask for a height above ground level, you give the height to the coax connection.
