Paddington
Scanning radio frequencies for the South East
hamtrektng
Call Sign: 2E0TZR
Paddington
Post by hamtrektng »
Also looking at Paddington station DMR freq. Anyone with info to share please do pm me.
bigbloke
Re: Paddington
Post by bigbloke »
453.550 DMR . its a CAP+ system though so multiple other channels
hamtrektng
Call Sign: 2E0TZR
Re: Paddington
Is it encrypted and do you know the tallkgroups and colour codes?
Cheers
Chris64ex4
Re: Paddington
Post by Chris64ex4 »
hamtrektng wrote: 04 Sep 2018, 23:25 Is it encrypted and do you know the tallkgroups and colour codes?
Cheers
Paddington not encrypted. Don't know about the talk groups but it's colour code 8. There is another DMR channel at Paddington on 453.9 MHz also colour code 8.
Reading station on 453.275 MHz colour code 5. Reading traincare Depot on 435.55 MHz also on colour code 5.
hamtrektng
Call Sign: 2E0TZR
Re: Paddington
Thanks Chris for the helpful info. When I go up in 2020 I will see if I can do more decode. Merry Christmas and a new year to you bud.
Chris64ex4
Re: Paddington
hamtrektng wrote: 26 Dec 2019, 00:39 Thanks Chris for the helpful info. When I go up in 2020 I will see if I can do more decode. Merry Christmas and a new year to you bud.
No problem and happy new year to you. Ive got a couple of Baofeng 1801 on order which should help me with Talkgroups etc.
Chris64ex4
Re: Paddington
Chris64ex4 wrote: 21 Dec 2019, 14:42
Cheers
It looks as if Paddington alternates between 453.550 and 453.900 MHz every so often. There appears to be alternative frequency for Reading station but I know not what it is.... :shock:
Chris64ex4
Re: Paddington
Chris64ex4 wrote: 31 Dec 2019, 14:05
No luck with talkgroups as yet, there must be something I’m not doing right with the Baofeng 1801’s.... :shock:
neil57uk1
Re: Paddington
Post by neil57uk1 »
You dont need the talk groups. Just put the frequencies in your scanner at it will do the rest.
Chris64ex4
Re: Paddington
neil57uk1 wrote: 23 May 2020, 19:22 You dont need the talk groups. Just put the frequencies in your scanner at it will do the rest.
I realise that (I took the AR-DV10 to work with me which is how I got the frequency / colour codes) but the question was asked about talk groups etc. Hence my leaving the DV10 behind and taking the Baofeng 1801 instead. In theory at least if you bang in the frequency and colour code the Baofeng should display the talk groups when the channel is in use. Possibly need to take the DV10 up again, not going to Paddington all that often at the moment to be honest.
