Antenna Identification help needed please...
- Call Sign: 26TM2714
Anyone recognise this antenna, well the part thats pictured at least... and can give any details on it like make, coverage etc?
WANTED
Galaxy Pluto, 2100, DX88HL, President Ronald (Or Equivalent)
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
Re: Antenna Identification help needed please...
could be a lemm gpl-27
W8JI
- Buick Mackane
Could be, I Have a lemm loft antenna with a fitting which is very similar if not identical
not seen one in many years but a mate had one on a standoff bracket in his loft that looked very similar, got caught up in it a few times.
W8JI
- Call Sign: 29SC01
Hello PeterA I had an antenna that looked like that many years ago. It was a fiberglass antenna. I think it was a 7/8 wave if memory serves and it was made by sirio. Along the same lines as the DV 27 tuning wise. I got lots of contacts on mine. I had it hanging off of the branch of a tree about thirty or so feet.
Appreciate the replies, will have a search based on the suggestions.
Thanks!
Thanks!
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
A Lemm I had and the Sirio Signal Keeper had a different central boss to that one, although they've probably changed the design may times over the years.
One thing we do know is it's missing all of its legs
ok, so looks like 100% on the Lemm GPL-27...
Shame it's missing the legs for the ground plane.
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- NightProwler
- Call Sign: 163TM186
Exactly like that one, I borrowed the sellers pics... I'm trying to find all the bits for mine from back in the day.NightProwler wrote: ↑22 May 2020, 21:47 A bit like this one
https://www.ebay.co.uk/itm/Classic-CB-R ... Sw~2ZewV6o
So far, I've only managed to find... the boss and the stand off bracket!
I can't find the original antenna, groundplane legs or the tank whip I used with the boss I modified?
I could have sworn I last saw them in the shed...
but no, now I actually want them... vanished into the abyss!?!
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- NightProwler
I had one exactly the same which I bought years ago when I lived in a high rise flat, Had it on the balcony. I gave it away to our very own Buick Mackane on here. I think he used it to support his 'tomato' plants
- Buick Mackane
Its laid in my loft supporting a ton of spiders webs Along with a whole heap of other antennasNightProwler wrote: ↑22 May 2020, 22:27 I had one exactly the same which I bought years ago when I lived in a high rise flat, Had it on the balcony. I gave it away to our very own Buick Mackane on here. I think he used it to support his 'tomato' plants
Wanna part with it?Buick Mackane wrote: ↑22 May 2020, 22:37Its laid in my loft supporting a ton of spiders webs Along with a whole heap of other antennasNightProwler wrote: ↑22 May 2020, 22:27 I had one exactly the same which I bought years ago when I lived in a high rise flat, Had it on the balcony. I gave it away to our very own Buick Mackane on here. I think he used it to support his 'tomato' plants
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
- NightProwler
Im sure I still got the original stand off bracket that came with it too as Buick didnt want it.
- Call Sign: 26AT239
Perhaps you could post up a couple of pictures of the stand off bracket, would give those of us that have the antenna but not the bracket to see what to look out for.NightProwler wrote: ↑22 May 2020, 23:07 Im sure I still got the original stand off bracket that came with it too as Buick didnt want it.
