Discriminator tap BCT15X
- stanogs68
Re: Discriminator tap BCT15X
because i was wondering does anyone out there know if its possible to put a tap on this scanner
love your familly
I found that information in google in a few seconds, and I'm not specially bright...
- stanogs68
were is then ? or dont to you want to share information and help
love your familly
- Auldgeek
- Call Sign: GM0BRJ
There's several sources of reference but this link contains comprehensive information on where to find the discriminator tap for a wide range of scanners, including yours.
http://psicorps1984.tripod.com/2003/200 ... nator.html
- stanogs68
Thanks for that ,Ive seen them but i thought there might of been like a walk through showing you but there isnt one out there for this radio ,thanks for the help though ill just try and work it outAuldgeek wrote: ↑21 Apr 2020, 07:59There's several sources of reference but this link contains comprehensive information on where to find the discriminator tap for a wide range of scanners, including yours.
love your familly
- New User
- Call Sign: 2E0YTT
https://www.discriminator.nl/index-en.html good site for tap info did mine following his info
On the Cap does the voltage matter? I'm seeing 16v and 35v, 20v, 25v on the zon.
Never checked mine just did it and it worked.
