hd1 dmr radio
hd1 dmr radio
Hi all I have a problem fm is working perfect when I try dmr doesn't pick anything up but when I go back to fm the dmr data is there any help would be grateful
- radiosification
Re: hd1 dmr radio
Are you certain there is anything to receive? DMR repeaters regularly transmit idle bursts which don't contain any audio for your radio to decode.
Also make sure you have the right colour code for the repeater. You will only hear voice traffic if you're on the same timeslot it's being sent on and I recommend you make sure promiscuous mode is enabled.
- Metradio
- Call Sign: G7HID
Re: hd1 dmr radio
Also if they have RAS (Restricted Access to System) enabled a DMR radio will hear nothing, but a scanner will hear it no problem..
Mike
Mike
- radiosification
Re: hd1 dmr radio
I don't think amateur DMR system use RAS.
- Metradio
- Call Sign: G7HID
Re: hd1 dmr radio
How do you know the OP is trying to receive an amateur repeater ?
Mike
- radiosification
Re: hd1 dmr radio
We're in the amateur radio section
- Metradio
- Call Sign: G7HID
Re: hd1 dmr radio
The HD1 can be loosely termed as a amateur radio than can be used for other uses, so between Amateur Radio - digital voice and data and Licensed (Commercial & Imported Transceivers), it is a bit of a toss up where questions go.. The OP is the only one who can guide us..
Mike
Mike
Re: hd1 dmr radio
Yeah I have the promiscuous on also I can hear the dmr voices on a 2nd radio but cant hear it on the hd1 but when I switch over from dmr to fm I can hear the dmr noise so I am also on the right frequency
- radiosification
Re: hd1 dmr radio
What's the other radio and how is it programmed? Is this an amateur system or business radio?
Re: hd1 dmr radio
Md380 amateur radio I cannot get my head round why dmr side of things isn't working even done a factory reset and still same can hear dmr on fm switch over to dmr nothing at all
- radiosification
Re: hd1 dmr radio
That is odd. Can you double check a few things? Make sure the channel is set to repeater mode instead of simplex. Made sure the colour code and timeslot are the same as the MD-380, and makes sure that promiscuous mode is turned on.
Re: hd1 dmr radio
I have done all that and still nothing not to sure if it's anything to do with enhanced settings it's not picking anything at all up with promiscuous mode
- thelad
Re: hd1 dmr radio
Drop Promiscuous mode and use the TG
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Re: hd1 dmr radio
Tried still doing same it's got an old firmware on thinking of updating it see if anything happens
- Call Sign: 26DG01
Re: hd1 dmr radio
Could they be using enhanced privacy? I thought the DMR spec silenced a receiving radio when Enhanced/encrypted flag is detected unless the appropriate key is available. This would explain why you can still here the data on FM.
Sent from my GP300 using DTMF
