SWR METER CB ( 27 Mhz ) SCHEMATIC MADE BY YOU
rooth
Post by rooth » 14 Jan 2020, 18:06
I didn't see a topic on this forum.
Have you made a diagram for a well-functioning CB radio SWR meter?
I am referring to an original scheme .
Re: SWR METER CB ( 27 Mhz ) SCHEMATIC MADE BY YOU
Post by ch25 » 14 Jan 2020, 18:40
I rather modified existing ones since they are crap.
rooth
Post by rooth » 14 Jan 2020, 19:09
I have a Zetagi Mod 203W 3-200 MHz that is not working properly.
After adjusting the head of the scale to 10, when I switch on the reflector, it remains to 10, it does not move at all. I checked everything, I did not cut off. The diodes are ok, the cable is the same ... I have no idea what he has .
It would help a picture from the inside if someone has the model.
That's what it looks like to me .
Post by ch25 » 14 Jan 2020, 19:58
No clue. Faulty switch?
