Westward PT2
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
See the number on the rear
Re: Westward PT2
Mine's a lot tattier than yours mate (the satchel's probably protected it well), but from what I can see, the serial number is 2012, not far away from yours.
I doubt if 2000+ of these ugly brutes were sold. They were more likely "numbered" by just the last 2 digits!
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
When I get around to cleaning my front panel I will just wash it down with a damp rag
- Call Sign: 45
Re: Westward PT2
Dave I like the radio it has a vintage look about it . I too struggle to understand why it had the case on the radio inside but I like it.
Sounds like you picked up a little limited number as I never saw one ever in the day.
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
It is a very strange set up to a point that the speaker is covered 3 times.
I knew they existed but only seen 3 or 4 for sale in the past 20 year's.
It would be interesting to hear from other owners to gauge the amount that was sold.
Re: Westward PT2
Here's the old advert from the 80's CB magazines:
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
I will see if I can find some adverts Dave as I am sure that there was another one
- timbob58
- Call Sign: 26tm957
Re: Westward PT2
IVE GOT ONE OF THEM SOME WHERE mine is 2039lambrettadave wrote: ↑14 Jan 2020, 17:31 It is a very strange set up to a point that the speaker is covered 3 times.
"The difference between genius and stupidity is that genius has its limits"
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
Wow I am impressed that at least 39 have been sold.timbob58 wrote: ↑18 Jan 2020, 16:13IVE GOT ONE OF THEM SOME WHERE mine is 2039lambrettadave wrote: ↑14 Jan 2020, 17:31 It is a very strange set up to a point that the speaker is covered 3 times.
Thanks for responding to the thread
- timbob58
Re: Westward PT2
my mrs got me it from a boot sale about 5 year's ago
all i done was replace'd the batt , and spray of switch cleaner
sorted
sorted
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
I am going to replace the battery in mine and I am going to try and use a ml145 whip in mine
Re: Westward PT2
As long as it doesn't collide with the switches and LEDs you'll be okay, apart from it overlapping the sides somewhat
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
I will try it tomorrow
Re: Westward PT2
I popped into the Toolstation clearance centre in Bridgwater todsy whilst passing and picked up a 2.1Ah battery for only £4.99. If I can be bothered to take the Westward apart one of the days, I'll change the battery.
The other battery I had as a freebie a while back is much too small Ah-wise, looking at Dave's that he kindly pictured.
- lambrettadave
- Call Sign: TM455
Re: Westward PT2
Some folks have all the luck....
I seen a 3.2ah as a direct replacement for about £9
