Superstar 360FM PB010-AA Beep.
- superstar
Re: What CB/11m Radio Stuff did you buy today? (2018)
bought this 148 mk2 locally, beep disabled,( what do i look for to enable the beep?) uk 40 on ch9 switch and alphas on the tone switch, apparently its been languishing in a shed for years ( i’ve cleaned it up a bit) it came with a ham 4200 base mic which the battery was dated 95, so possibly last used around that time, seems to work reasonably well
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- slamjam
- Call Sign: 26DT871
If it's a mk2 the orange wire which goes to the hole on the pcb marked "Peep", near the mic socket has probably been cut or removed. Should be easy to reinstate.superstar wrote: ↑12 Jan 2020, 18:34 bought this 148 mk2 locally, beep disabled,( what do i look for to enable the beep?) uk 40 on ch9 switch and alphas on the tone switch, apparently its been languishing in a shed for years ( i’ve cleaned it up a bit) it came with a ham 4200 base mic which the battery was dated 95, so possibly last used around that time, seems to work reasonably well
26DT871 - Ipswich UK
- superstar
cool thanks i’ll av a lookslamjam wrote: ↑13 Jan 2020, 07:34If it's a mk2 the orange wire which goes to the hole on the pcb marked "Peep", near the mic socket has probably been cut or removed. Should be easy to reinstate.superstar wrote: ↑12 Jan 2020, 18:34 bought this 148 mk2 locally, beep disabled,( what do i look for to enable the beep?) uk 40 on ch9 switch and alphas on the tone switch, apparently its been languishing in a shed for years ( i’ve cleaned it up a bit) it came with a ham 4200 base mic which the battery was dated 95, so possibly last used around that time, seems to work reasonably well
Cb handle
Cb handle
- superstar
had a look and cant see anything marked peep near the mic socket, heres a pic of the board, some loon has added positive and negative sockets to the rear
Cb handle
Cb handle
- slamjam
Should be here: Orange wire going to the pcb labled Peep
- astradyne
The RF meter presets appear to be set way too high. Also the driver bias preset is cranked up full. The connectors on the back are pointless. It may be worth your while sending it off to Nick for a clean up and service.
- superstar
thanks for the pics Slamjam, looks like mines a different board, it ends with AA and not AB, there’s no beep marked on board, and yes astradyne i think i’ll send it Nicks way and get all this junk out of it and put back to standard, here’s a pic of the board number too, what does it make this then an early mk2 or is it a mk1?
Cb handle
Cb handle
- astradyne
Being a PB-010AA board makes it a very early MK2. The PCB has a slightly different layout to the PB-010AB.superstar wrote: ↑14 Jan 2020, 08:01 thanks for the pics Slamjam, looks like mines a different board, it ends with AA and not AB, there’s no beep marked on board, and yes astradyne i think i’ll send it Nicks way and get all this junk out of it and put back to standard, here’s a pic of the board number too, what does it make this then an early mk2 or is it a mk1?
- 13EL121
- Call Sign: 13DA121
The Peep wire should be the orange wire marked in the photo. But this is off topic. Should be moved to repair forum.superstar wrote: ↑14 Jan 2020, 08:01 thanks for the pics Slamjam, looks like mines a different board, it ends with AA and not AB, there’s no beep marked on board, and yes astradyne i think i’ll send it Nicks way and get all this junk out of it and put back to standard, here’s a pic of the board number too, what does it make this then an early mk2 or is it a mk1?
- 14CS06
- cb4ever104
It might be the orange wire with the black tape on it . Remove the tape and see if it's been cut before . If it has then try cutting it again and see if the beep dies .
S.
- timbob58
- Call Sign: 26tm957
Re: Superstar 360FM PB010-AA Beep.
Know it was some time ago but.. How did you get on with it in the end Jason ?
"The difference between genius and stupidity is that genius has its limits"
- 14CS06
Hello
COBRA 148 GTL-DX
"MKI & MKII"
PB-010 AA & PB-010 AB
http://cobraworxshopz.com/cobra_148gtl-dx_13.html
Claude
COBRA 148 GTL-DX
"MKI & MKII"
Claude
On the PB010AA disconnect one end of C162 to silence the bleep.
Barney
Barney
