Adjust modulation inside President JFK mainboard PA338AB ?
- rooth
Hello everybody !
Do you know how modulation at JFK President ( mainboard PA338AB ) can be increased?
I made the microphone change from the dynamic variant to the elecret. It is ok, but I would like to increase the modulation a bit.
- Call Sign: Lemmy
Re: Adjust modulation inside President JFK mainboard PA338AB ?
Vr12
- cb4ever104
Thought you might have tried this first before going to the trouble of changing the element.
- rooth
@ ch25 : I'm not VR12 on motherboard .I looked better on the motherboard and I think it's VR5 ... What do you think?
- Call Sign: Lemmy
Nope, it is PWR pot. Any AM mod/AMC labelled?
- rooth
Only SQ , DEV , RF.M and S.M .
I think it must be RF.M ...?
- Call Sign: Lemmy
On 338 board there is no am mod adjustment. Just found a schematic.
You can try to remove Q31 to disable limiter, but you need to adjust micgain to avoid overmodulation. Try that, if it will be too strong we try to modify AMC level other way.
- rooth
OK, I'm trying. Thanks!
- 163TM847
DEV is for FM modulation [DEVIATION] Dont adjust it too high though or you may over deviate.
- cb4ever104
Weird, or what ? Something to note for the future, and yet another reason not to buy a JFK
- rooth
@cb4ever104 : No problem, I like to experiment Radio is great !
- 14CS06
- Call Sign: Lemmy
What is have to do with topic we discuss here Claude?
- rooth
The limitation with Q31 I see is for AM ... For FM I am interested in canceling the limitation.
I did not find any other references on the internet related to this ....
I think in the last instance I try to increase the power from the adjustable VR5 motherboard.
Does the power increase to the left?
Do you need any further changes?
- Call Sign: Lemmy
Do not cancel FM limiter, you will become unreadable.
