Dual 102 ss whip base
Zero58
New User
New User
Call Sign: Zero58
Post by Zero58 »
I want to build a base antenna out of 2/102 stainless steel whips, using one as the driver and one as the counterpoise! Do I need to use 6 inch springs to extend it to 108 inches, or not? put it up horz about 30 feet and see what happens! Any Ideas in this would be helpful. Thank You.
Snow Bird
Call Sign: KJC5319
Re: Dual 102 ss whip base
Post by Snow Bird »
yes it needs to be Total of 108 inch on each side keep each end apart about 1 to 1 1/2 inch . have fun I have buld a lot of ant. that is part of the fun. ENJOY
