I know some of you are going to say I should know this being a Ham...
So here are the analog simplex frequencies:
01. 433.4000 MHz U272
02. 433.4250 MHz U274
03. 433.4500 MHz U276
04. 433.4750 MHz U278
05. 433.5000 MHz U280 FM Calling Channel
06. 433.5250 MHz U282
07. 433.5500 MHz U284 Used for Rally/Exhibition talk-in
08. 433.5750 MHz U286
What are the simplex Digital Frequencies?
70cm Simplex Digital Frequencies
- Werthers
- Call Sign: G4RMT
Re: 70cm Simplex Digital Frequencies
There's no agreed channelisation for 70cm for digital comms as far as I'm aware, but the RSGB say this
432.491-432.493 MHz Personal Weak Signal MGM Beacons (BW: 500 Hz max)
433.800-434.250 MHz Digital communications & Experiments, including…
434.000 Low Power Non-NoV Personal Hot-Spot usage
437.000 Experimental DATV Centre of Activity (Typically QPSK)
438.800 Low Power Non-NoV Personal Hot-Spot usage
- Werthers
Cheers for the info. I've been having a look online and found 433.625-675 MHz: Digital communications (25 kHz channels) also 433.800-434.250 MHz: Digital communications.
- Call Sign: 2E0UCW
Analogue and Digital simplex share the same frequencies except the calling channel - digital uses 438.6125MHz
https://rsgb.services/public/bandplans/ ... n_2019.htm
There are also 8 non-official digital simplex channels for 70cm
Motorola DM4600 ; Anytone 578 ; Anytone 868 ; Anytone 878 Plus
Whistler TRX-1 ; DV Mega ; Duplex Hotspot ; Zumspot USB
www.dmrguide.uk ; www.dmr-uk.net
- Werthers
I have these programmed into my DMR Simplex Zone2E0UCW wrote: ↑11 Sep 2019, 19:13 Analogue and Digital simplex share the same frequencies except the calling channel - digital uses 438.6125MHz
01. 433.4000 MHz
02. 433.4250 MHz
03. 433.4500 MHz
04. 433.4750 MHz
05. 438.6125 MHz DMR Calling Channel
06. 433.5250 MHz
07. 433.5500 MHz
08. 433.5750 MHz
09. 438.5875 MHz
10. 438.6000 MHz
11. 438.6250 MHz
12. 438.6375 MHz
13. 438.6500 MHz
14 438.6625 MHz
I just need two more channels to complete my DMR Simplex Zone of 16 channels.
