Cobra GTL-150 no receive
Blackolive
Call Sign: G4WCS
Post by Blackolive »
Picked one up off ebay, there was a youtube video of it working on transmit and receive. Came without a mic, but Ive got a cobra mic. Ive had to rewire it slightly, but the receive side still appears to be dead. Screwdriver to the volume pot wiper proves the audio amp is working, but theres no radio hiss, changing the mode switch doesnt do anything, and its not actually receiving anything.
Its transmitting fine.
What does plugging the mic in actually do, Im wondering if power isnt being routed to the receiver side ?
Otter
Call Sign: 26TM439
Re: Cobra GTL-150 no receive
Post by Otter »
The mike usually enables the receive audio path on Cybernet radios. It's probably wired incorrectly.
Put a dummy load on the radio. Determine which pin is ground with a multimeter between the mike socket pins and the -ve power lead with the radio switched off. Power up the radio and put it in FM mode (so you'll get a nice hiss when it works) then link between the ground pins and other pins in turn. One pin should put it in Tx, one should give you a nice FM hiss, the remaining one is the audio pin.
Wire the mike accordingly.
Blackolive
Call Sign: G4WCS
Thanks, Ill try that.
astradyne
Post by astradyne »
These are the same radio as the Laffayette 1200. Built by Cybernet so the mic wiring would be different. Simply swapping over pins 1 & 2 with each other and the same for pins 3 & 4 is all that's required to switch Uniden to Cybernet wiring.
dt307
Call Sign: 163dt307
Post by dt307 »
short the 2 pins with a small bit of wire and rx should work
163dt307-chris
― Albert Einstein
Blackolive
Call Sign: G4WCS
Right here’s where Ive got tonight. Pin 3 is receive and theres now a very faint hiss from the speaker and a buzz when i touch the volume pot. External speaker causes oscillation so Im suspecting a dry cap around the audio amp. Main voltage regulator is ok, and theres voltage on the collector of the first rf amp stage. No increase in noise when antenna plugged in, no change in hiss when mode selector operated, and unresponsive to signal at either 27 or 10.695 mhz. Has anyone got a component layout to make life easier to go round and check voltages please ?
Blackolive
Call Sign: G4WCS
And as its txing ok Im not suspecting an out of lock on receive vco yet but could do with test point identification
14CS06
Post by 14CS06 »
Hello
Schematic
Claude
Blackolive
Call Sign: G4WCS
Thanks Claude, Ive got the scematic.
14CS06
Post by 14CS06 »
Blackolive
Call Sign: G4WCS
Found this useful article. I was already suspecting the dc switching circuit http://www.m0ysu.com/121d4x.html
astradyne
Post by astradyne »
It is odd though as the radio was sold as working and there was a YouTube video supporting this. Then it arrives with a major fault - no RX.
Are you certain they sent you the actual radio in the YouTube video?
Blackolive
Call Sign: G4WCS
Fixed. It was Q40 which switches supply to the receive side, I may have popped it trying to work out which pins to link on the mic socket or maybe just a random failure. Using the antenna analyser as a sig gen
https://youtu.be/Tb9Cy4k1Qkg
163TM847
Post by 163TM847 »
Blackolive wrote: 11 Sep 2019, 06:24 Fixed. It was Q40 which switches supply to the receive side, I may have popped it trying to work out which pins to link on the mic socket or maybe just a random failure. Using the antenna analyser as a sig gen
The most common fault for the 1318 to blow is because a bezel screw was placed in bottom middle, If it goes down to far it shorts to the mode switch blowing the 1318 RX switch.
Blackolive
Call Sign: G4WCS
Ill have a look at that thanks
