MRF477
- cb4ever104
MRF477
Is this 477 real ?
https://www.ebay.es/itm/202690097604
Doesn't look right to me . Saying that I'm probably wrong
- 14CS06
- cb4ever104
Re: MRF477
I don't like it Claude . Aren't there normally 2 little indentations on the main body ? Also , the letters don't look right to me either .
- Call Sign: 4a0026
Re: MRF477
Hello dears! when I had President Jackson I accidentally burned the mrf477 transistor. I successfully replaced кт920 (Russia)
- Call Sign: 4a0026
Re: MRF477
I had to Unscrew the black radiator and drill a hole for the nut inside .output power has not changed
- Call Sign: 4a0026
Re: MRF477
in any case, fake transistors made in Russia does not happen....
- Otter
- Call Sign: 26TM439
Re: MRF477
It looks good to me.
- cb4ever104
Re: MRF477
- Mitch
- Call Sign: M1TCH
Re: MRF477
Have the pins been tinned? Back in the day we called these 'gold leggers' because the pins were gold coloured. They were expensive then too.cb4ever104 wrote: ↑30 May 2019, 11:58 Is this 477 real ?
Don't look right to me . Saying that I'm probably wrong
The perfect face for radio.
- Otter
Re: MRF477
The 1990s ones didn't have gold legs. They did in the '80s.
- dt307
- Call Sign: 163dt307
Re: MRF477
finished this 1 off last night with a sd1446 but a mrf455 also work the same and cheaper and will last longer than a 477 less than £30 new from a main uk dealer via rm italy.
just a thought for you sammy, i know you can make a pcb up to hold the 455/1446 but i fitted a nos driver and used final and this way the bill to the customer fitted is going to be £25.
2x560pf caps removed,bias diode removed,new 4001 bias doide fitted so not hard to do
163dt307-chris
― Albert Einstein
― Albert Einstein
- dt307
Re: MRF477
side note incase any1 tries it.
you must ground 1 of the emitter tabs via 1 of the screws.
the mod is rogerbirds.....( lincoln guru) detials on the cbtricks website under hr2510
163dt307-chris
― Albert Einstein
― Albert Einstein
- Otter
Re: MRF477
All of these were bought before Chinese fakes were even thought of.
The modern fakes on eBay have the word "ON" in a circle. On semiconductors never made MRF477 or MRF497."To this day the words Stirling bridge conjour pride in every Scotsman's heart, while to an Englishman those same words conjour literally no feelings at all." - Cunk on Britain S1 E1
- cb4ever104
Re: MRF477
It's strange how the sight of a few transistors can get the juices flowing
- Call Sign: 29VLF125
Re: MRF477
Any so called MRF477 with a date code later than 95 is fake they stopped making them in 95.
real 477s the plastic is black not slate or gray the one in the pic is the real deal to look for anything that has any other logo than the Motorola circled M is not.
Re ON Semi as Otter said they never made 477s or 455s in fact they dont make any RF transistors for the HF bands.
Techquest AKA Jedi
