Torchlight procession stewards active tonight
stratocaster
Post by stratocaster » 30 Dec 2017, 18:55
Stewards for the torchlight procession are active on 456.450 ctcss 103.5 tonight. Buzzing with activity!
gmham
Call Sign: 108TM154
Re: Torchlight procession stewards active tonight
Post by gmham » 30 Dec 2017, 23:02
Thanks for sharing, I take it the only benefit off a ctcss tone for a scanner user is if two different users were using the same freq and setting this tone would allow the scanner to just receive the one wanted transmission ?
Icom IC7300 HF /6 mtrs
Kenwood TS711E 2 mtrs ssb
108-TM-154 - John
stratocaster
Post by stratocaster » 31 Dec 2017, 12:53
Hi John, I had unwittingly set up the scanner on the ctcss search under the main frequency and didn't turn the ctcss search off! It's the first time I've heard a hit on that frequency. You are correct in what you say about the ctcss tone.
smscot
Post by smscot » 31 Dec 2017, 19:51
Have they now changed channel?
smscot
Post by smscot » 31 Dec 2017, 20:15
Noticed a lot of them have moved channel. Is there other frequencies for that channel that anyone knows?
stratocaster
Post by stratocaster » 01 Jan 2018, 14:02
I'm up in Glenrothes just now and am nowhere near a scanner. When I return I'll set up a search for other frequencies in the 400-500 range and if I find anything of note, I'll be sure to post up my findings! But I can confirm that the range of the broadcasts were from Holyrood park all the way up the Royal mile, so power output and range from the radios the stewards were using wasn't a problem.
smscot
Post by smscot » 30 Dec 2018, 16:50
You think this will be on tonight mate?
elliotg
Post by elliotg » 30 Dec 2018, 18:27
They are still on 456.4500 @ 18:25pm. There was no activity on this freq at 16:30pm but i heard engineers doing radio tests on this freq then heard control say all user were moving from digital channel to analogue. So there must have been some sort of problem with their digital channel.
Whistler TRX-1
elliotg
Post by elliotg » 31 Dec 2018, 18:09
Medics on 456.4625
Whistler TRX-1
brew_dog
Post by brew_dog » 12 Mar 2019, 13:36
elliotg wrote:
31 Dec 2018, 18:09
Medics on 456.4625
was this on DMR ?
GD-77
Mototrbo dp4800
Hytera PD785
Hytera PD505
TYT MD380
elliotg
Post by elliotg » 16 Mar 2019, 08:20
Yes it was.
Whistler TRX-1
