AT-6666 programming lead pinouts?
AxleJack
Call Sign: VK2AXL
Post by AxleJack »
Hi folks
I need a programming lead for my Anytone AT-6666. I have heard a rumour that although this lead is not a USB to mini-USB as it appears, it is possible to make a programming lead from a USB to mini-USB by cutting it in half and rejoining the cores in the correct order.
Can anyone confirm this and give me the connections?
Jack
theEarwigger
Call Sign: M0RZF
Re: AT-6666 programming lead pinouts?
Post by theEarwigger »
Hi Jack,
That's not right, unless they changed the design of the '6666. You need a USB-serial adaptor and a mini-USB lead. USB-serial can be bought from eBay (China) for about £2. Then get an old mini-USB lead and cut off one end, leaving the mini-USB bit the length you want.
The connections are more difficult. I sold my AT6666 and the lead a few months ago, and didn't keep a record of the connections. But with a mutimeter you can work it out. From what I remember there is only the serial data and ground used. With the meter you can check out where the ground is. The serial data pin may well be in the meg ohm range, but the other 2 pins will be open.
Worth plugging in a mini-USB cable and checking through the pins with an ohm meter (radio off obviously)?
It may be easier to just buy the programming cable from somewhere like Knight's CB if you are not experienced in electronics...
AxleJack
Call Sign: VK2AXL
Post by AxleJack »
Thanks. But of further consideration, I have ordered the ready made lead.
I had been lead to believe it was easier than that, but for the cost I think a proper one is worth it.
Cornelius
Call Sign: Cornelius
Post by Cornelius »
My CRE 8900 also have a mini-usb plug on the radio, but the cable are actually an usb-to-serial adapter...
I'm guessing it's the same for the AT-6666. :)
Otter
Call Sign: 26TM439
Post by Otter »
santy
Call Sign: LW6DZO
Post by santy »
Hi for everybody. I´m Santiago From Argentina. Does sameone tested te USB-Serial cable to program an Anytone 6666? Thenks a lot!
Otter
Call Sign: 26TM439
Post by Otter »
It should work, but I haven't tried it. If you want to make your own I will test it on the 9900.
