Hi
Recently bought x2 BF-888s noticed a strange "rattle" sound when I moved/walked around with the radios, I took the antenna of both radios and moved them around a normal with just the radio body, no rattle.
shook gently each antenna side to side and found they both had the rattle, has any one else had this on there antennas ? both TX/RX 100% o.k., no scratchy noise coming through the speaker, just this rattle sound from the antenna.
Thanks for any info if you have had the same rattle sound from the antenna.
Baofeng 888s antenna question
- thelad
Re: Baofeng 888s antenna question
Be just the spring part inside the antenna moving. Cant expect much for the price.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- Call Sign: G4RMT
Drill a small hole half way up and squirt in some superglue - that will reduce it.
Hi
Thanks for the reply's, I just wondered if its a common thing on these radios ?
- thelad
Not noticed it on any of mine.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- Auldgeek
- Call Sign: GM0BRJ
I have a pair of these and haven't noticed any rattling
Auldgeek - Drew
Hi
O.k. thanks all for the reply's must just be mine then they still work fine.
