TYT MD 380.... err..
- 310den
OK so I thought I would look into this digital malarky and got the above radio (UHF) and loaded up a local (ish) codeplug and can hear chat on GB7MH.
Is there anyone near me that has details of frequencies I can add or a codeplug loaded with digital stuff I can listen to? Not just amateur, others also. Would like to listen around on digital while i get my head around this radio and learn a bit more on the digital side.
Thanks.
Thanks.
- Auldgeek
- Call Sign: GM0BRJ
Re: TYT MD 380.... err..
Check the first post out. Might be of help. My MD-380 only has the codeplug for my semi local repeater but I tend to use my 380 simplex and use my DV Mini as a hotspot on UHF and I can link into the DMR network that way. Anyway, Admirals codeplug may be of use to you.310den wrote:OK so I thought I would look into this digital malarky and got the above radio (UHF) and loaded up a local (ish) codeplug and can hear chat on GB7MH.
Thanks.
viewtopic.php?f=8&t=53942
- 310den
Thanks for the reply Drew. I have installed that codeplug but not hearing much but not my area. Currently got GB7MH codeplug loaded which is working for what is intended.kilimax wrote:Check the first post out. Might be of help. My MD-380 only has the codeplug for my semi local repeater but I tend to use my 380 simplex and use my DV Mini as a hotspot on UHF and I can link into the DMR network that way. Anyway, Admirals codeplug may be of use to you.310den wrote:OK so I thought I would look into this digital malarky and got the above radio (UHF) and loaded up a local (ish) codeplug and can hear chat on GB7MH.
Thanks.
Was hoping to use it as a digital scanner to listen to 'interesting' transmissions.
Cheers.
Have a look in the scanning frequencies section of the forums for your area, someone has probably been scanning with an SDR dongle and posted some frequencies already, if not then start a new thread in there.
- Auldgeek
- Call Sign: GM0BRJ
To be fair, that codeplug would have been put together based on Admirals location and reception capability but it should have hopefully allowed you to see how to use it as a baseline and add frequencies to suit you. I think the scanning section churns out some DMR & analogue frequencies and if you post a request for frequencies and colour codes for active transmissions near your location, you can build up a decent database.310den wrote:
Cheers.
I've just very recently taken delivery of the new Retevis dual band DMR radio and I received a codeplug for all UK amateur repeaters. Like you, I will be looking for other frequencies to add.
Keeps us out of trouble, at least in some ways!
Hi 310den, I can't afford a DMR scanner, so the way I do it is crude and a bit time consuming as it's a three stage thing.
I use a ten quid SDR TV dongle to scan around 450Mhz to 457Mhz and 162Mhz to 169Mhz (the most active for DMR near me), you soon get used to the waterfall signature of DMR stuff, I port it to DSD+ to get the colour code and see if it's encrypted (if encrypted then don't go any further as it's a waste of time), don't worry if DSD+ doesn't output the audio if you're too far away from the signal, the 380 will receive it.
Stage 2: As the frequency of the cheapo dongles is usually horribly out, and even with calibration they wander off when going up or down, so I then put the best guess of the frequency from SDR# or HDSDR into a decent analogue scanner set to 12.5Khz steps and when the stream is on the waterfall I click around the scanner to get the proper frequency by hearing the 'motorboat' noise.
I now have the exact frequency, colour code, TG (if not using promiscuous) and timeslot, it then goes into the 380 and voila, crude, but effective if you can't justify splashing out on a DMR scanner.
I have now retired and moved back to MK, so I now need to start all over again as that codeplug is for Peterborough.
- Farty
You in MK now Admiral? Not a gazillion miles from me.Admiral wrote: I have now retired and moved back to MK, so I now need to start all over again as that codeplug is for Peterborough.
- 310den
Hi AdmiralAdmiral wrote:Hi 310den, I can't afford a DMR scanner, so the way I do it is crude and a bit time consuming as it's a three stage thing.
Thanks for that. I do have an SDR reciever so will try that. Some good tips there.
- stanogs68
great idea there Admiral ,putting the frequency into your analogue scanner till you get the motorboat noise to nail done the frequency nailed down ,never thought of thatAdmiral wrote:Hi 310den, I can't afford a DMR scanner, so the way I do it is crude and a bit time consuming as it's a three stage thing.
love your familly
- 310den
Can you enter that info directly in the 380 or does it have to be via the software then load it up?310den wrote:Hi AdmiralAdmiral wrote:Hi 310den, I can't afford a DMR scanner, so the way I do it is crude and a bit time consuming as it's a three stage thing.
I think you can only edit with the radio keyboard, I don't think you can create new channels, I'm not 100% sure on that as I always use the software.
Or you could do it the other way around stan, search on a decent analogue scanner for motorboat sounds and then get the digital info from SDR/DSD, I personally prefer to use the SDR first as I get a 9Mhz specrum on mine which means I can effectively monitor the whole active band at once.stanogs68 wrote: great idea there Admiral ,putting the frequency into your analogue scanner till you get the motorboat noise to nail done the frequency nailed down ,never thought of that
Yeah, back on the darkside after three years away.Farty wrote:You in MK now Admiral? Not a gazillion miles from me.Admiral wrote: I have now retired and moved back to MK, so I now need to start all over again as that codeplug is for Peterborough.
Is it me Farty, or does GB3MK have a nasty hum on analogue?
- Farty
Never tried to access it matey, but will try later. I usually do my rag chewing through VA, though that's gone quiet lately.
I can hear VA but can't access it as I'm just using my handies for now as I'm staying with friends until my place is finished, hopefully this side of xmas, then I can get something in the air.
Back on topic, I'll be getting a VHF 380 as I don't trust the dual banders coming out at the moment since the Bumfeng dualband DMR disaster.
