On Site Communications have got sites at Kingsbarns and St Andrews on the OFCOM site
Freqs on the OFCOM site are
TX RX SITE
163.7125 159.2125 Kingsbarns
158.6125 158.6125 Kingsbarns
163.8875 159.3875 Kingsbarns
163.5125 159.0125 Kingsbarns
164.4875 159.9875 Kingsbarns
158.5375 158.5375 Kingsbarns
163.9375 159.4375 St Andrews
164.0125 164.0125 St Andrews
164.4375 159.9375 St Andrews
165.000 165.000 St Andrews
163.875 159.375 St Andrews
163.725 159.225 St Andrews
163.5625 159.0625 St Andrews
163.525 159.025 St Andrews
Cant find any licence allocation for Carnoustie on the site so someone will have to get the freq counter out.
I'm working in the St Andrews area so will post what I find
Dunhill Links Championship 2016 Fife freqs
Re: Dunhill Links Championship 2016 Fife freqs
CSP doing car parking using Motorola DP400 handsets. Got the freq counter on one of them. Was up in the ghz
So anyone have any ideas ??
CSP are using
for car parking - 449.3125 - CC3 S2
also in the handsets are
449.400 CC3 S2
449.475 CC3 S1
Hope this is of assistance to someone, seeing as these handsets are not on hire but are marked CSP.
449.400 CC3 S2
449.475 CC3 S1
If the s1 and s2 is for timeslot then it doesn't matter for simplex.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Just says repeater slot on the RT3. Thats what I entered then into
Timeslot and repeater slot are the same thing, it is the repeater that has the slots, as these are simplex channels the slot won't matter, so for a channel that has selected slot 2 you will still hear the traffic if you programmed in as slot 1. (Assuming you have the correct talkgroup programmed in the rx group list)
The rt3 has hacked firmware you can instal that allows rx of all groups if you are on the correct frequency and cc, along with the timeslot if it's a repeater channel.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
