Baofeng BF-888s Review
Re: Baofeng BF-888s Review
Hi, may I first say hello as new to this forum. I have been aroud radios and CB for a long while. Relation bought me two BF888S for Christmas with programming lead. Managed to get chirp up and running and talking with the radios. Problem is that I have programmd all of the PMR446 frequencies but try as I might cannot get them to talk to each other, I have set both radios to the same setting. Can any of you see any obvious errors on my programming part I cant attach a screen grab, so listed the settings
Loc -1
Freq - set to PMR frequencies
Tone Mode - None
Tone - 88.5
Tone SQL - 88.5
DTCS code - 023
DTCS RX - 023
DTCS Pol - NN
Cross mode - Tone - Tone
Duplex - -
Step - 6.250000
Mode - FM
Power - High
Any help would be grately appreciated
Garry
Loc -1
Tone Mode - None
Tone - 88.5
Tone SQL - 88.5
DTCS code - 023
DTCS RX - 023
DTCS Pol - NN
Duplex - -
Step - 6.250000
Mode - FM
Power - High
Garry
- radiosification
I'm not exactly sure what the -- signifies for duplex, but duplex should be set to off, not + or -.
- thelad
Take the tones off and try them.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Radiosification is right - one of CHIRP's "quirks" is it has a negative offset turned on by default. Change that to none, and you'll be reet. I have a feeling setting it to Off actually makes the channel receive-only, but I could be misremembering.
Setting tone mode to OFF means you aren't using any CTCSS or DCS, which leaves you wide open to interference from other channel users - set it to TSQL to use CTCSS, or something else (possibly DSQL from memory) to use DCS.
Guys, all sorted, you were right on, turned duplex off, perfect even got the uv5r listening to them. Brilliant.
So if I set TSQL do I have to change any other settings?
Many thanks
Garry
Many thanks
Garry
- radiosification
You can use CTCSS or DCS (TSQL) to filter out other users. Just make sure it is set the same on all radios you want to use to talk to each other.
If you're using these radios with some other, proper pmr446 radios you may need to look up a chart to see which tone corresponds with which "sub channel" or whatever the manufacturer of that set decides to call it.
- Auldgeek
- Call Sign: GM0BRJ
Just after picking up two of these brand new for £20 delivered. Programmed them up really quickly with Chirp. 8 X PMR446 + 8 X 70cms.
Quite well built. Can't quite believe the price. Bit of a steal.
A bit of a noob question, if I program the 888 to the 8 PMR446 frequencies, can it then scan the CTSS/DCS codes so it can pick up other rados (eg Cobra. Binatone etc) or do these also need to be pre-programmed ?
It will not scan codes. They have to be programmed manually and are fixed to the channel.
How do these compare to the UV-5R ? Anyone have both and can comment ?
A few questions on the 888S:
1) Is an aftermarket aerial a good upgrade to increase sensitivity ? Any recommendations ?
2) Any reliable UK suppliers you would recommend at a good price ?
Anyone bought from http://www.baofengradio.co.uk/ It looks like an official Baofeng site but I don't think it isSpy wrote:A few questions on the 888S:
- StormShadow
Baofengradio an official site lmao they are about as official as the Baofeng as it getsSpy wrote:Anyone bought from http://www.baofengradio.co.uk/ It looks like an official Baofeng site but I don't think it isSpy wrote:A few questions on the 888S:
- Metradio
- Call Sign: G7HID
Mike
- FakeJake
- Call Sign: 2E0SEY
Ive used this site before. Good service. http://www.handyradio.co.uk/handheld-radios/baofeng/
Jake 2E0SEY
Saltney, near Chester (Cheshire-Flintshire border)
Monitoring 2m simplex (when I can)
Dysgwr Cymraeg
Dysgwr Cymraeg
