ft-221 cleanup and repair
- Crusader
Re: ft-221 cleanup and repair
Really? we will see,who did you sell them too??get my money back on the microphones as i sold two of those recently for £20 each & the power leads will get about £15 each for and the radios themselves just part them out
- Buick Mackane
Only pulling yer coax Not a bad price, And im sure you'll be able to save at least one of them, Or worse case you'll easily get your money back on parts etc
- Crusader
Wind up merchant yeah i would like to get one of them working,then part the other one out,could'nt resist at that price
- Crusader
PLL02A wrote:Only pulling yer coax Not a bad price, And im sure you'll be able to save at least one of them, Or worse case you'll easily get your money back on parts etc
It gets better pal,not only were there x6 channelised crystals that i wanted inside these two scrappers but there was also a Mutek front end fitted inside one of them!!
- Buick Mackane
resultCrusader wrote:PLL02A wrote:Only pulling yer coax Not a bad price, And im sure you'll be able to save at least one of them, Or worse case you'll easily get your money back on parts etc
- Crusader
Yep,just had one better result,one of these radios is fully working
- Crusader
- Buick Mackane
ok ok i heard you the first time, stop bragging Good stuff, But its about time you left a bargain or two for the rest of us
- dt307
- Call Sign: 163dt307
Great find and a nice result
163dt307-chris
― Albert Einstein
― Albert Einstein
- Crusader
PLL02A wrote:ok ok i heard you the first time, stop bragging Good stuff, But its about time you left a bargain or two for the rest of us
Not a chance,you lot can go hunt your own bargains as for bragging..nah i don't do that,that is Bigpimps job
- Crusader
Cheers Chrisdt307 wrote:Great find and a nice result
Be a little wary about using the tone in jack, I believe these were used for taking the output for YC221 counter as a modification.
- Crusader
Yep it is ok,the socket has'nt been modified so it is still a tone in socket,cheers anyways
