hrd problems
- skiptalker
hrd problems
hi, im having a problem with hrd . have it working ok with ic7000 an a usb to serial cable. well it works fine for 5 mins or so , i can change frequencies ok on the radio just by clicking on the cluster but after 5 mins i get an error application is not responding an i have to shut hrd down an unplug the the lead from computer an reconnect it then it works again but only for 5 mins or so.. any ideas ??
68 TM 010
OP: KIERAN
IC 7000 / IC 706 MK2G /F510 / UV5R / LDG IT100/ WOUXUN 920
UBC 800XLT / 230XLT
A99 /IMAX 2000/ WILSON 1000/ X30 / X50 / G5RV
OP: KIERAN
UBC 800XLT / 230XLT
- ClubbaUK
Re: hrd problems
Sounds like your USB could be switching off due to RF interference.
I can highly recommend you try a 'Juice Bits' USB extension lead, they are very well shielded and have eradicated RF interference for me. You'll find them on Amazon.
Also make sure no cables/leads/coax from your radio cross over any PC cables as capacitance coupling can occur.
