Alinco DX-R8E Serial Commands
scan125
Call Sign: 26TM8080
Post by scan125 »
Does anyone have or can provide info/pointers on the serial API commands for the Alinco DX-R8E (or DX-SR8 / DX-SR9) unit please.
owza
Call Sign: M0
Re: Alinco DX-R8E Serial Commands
Post by owza »
scan125
Call Sign: 26TM8080
Post by scan125 »
Thanks.
Have already seen and noted this BUT he is actually hacking the receiver's detachable control head to main unit interface and not using the exterior serial connection point.
I've yet to trawl through the schematics to see if there is any commonality between the two different Txs & Rxs. (read head interface vs external interface)
owza
Call Sign: M0
Post by owza »
Oh OK, I notice an Extio.dll exists for the Alinco, perhaps this contains the commands? If whoever wrote it can be tracked down?
scan125
Call Sign: 26TM8080
Post by scan125 »
Well I've found a few commands on the web for the DJ-X11 which is supposedly similar.
Won't know till after Xmas as my DX-R8 is currently sat firmly under the Xmas tree :)
Once I get my hands on it I be able to hopefully work out a reasonable command list by "inspection". Perfectly legal and above board. Just a pain in the arse!
owza
Call Sign: M0
Post by owza »
It's a nice radio, the IF Shift work well. The manual is wrong, it works fine in AM mode.
tomos
Post by tomos »
Pm sent. I may be able to help you out with the command set
scan125
Call Sign: 26TM8080
Post by scan125 »
tomos
Can't see the PM yet.
Please re-send.
Nick
tomos
Post by tomos »
I have sent that again ... If you can PM me with an alternate email address NIck ?
