- kr0ne
You could try diodes for dropping the fan voltage... less heat!
- sureshot
- Call Sign: 26TM413
Yes i could have dropped the 3 volts with a few series diodes, but the fan is only about 120 mA total and with the single series resistor it runs cool to the touch. It was a 4 lead fan so pwm, but its fine running fixed speed on the 2 wires needed to spin it up, its about the same speed as if the pc was in use, fairly quiet. I could of stuck another 2 lead 92mm fan in it, but its got to stay a bargain to covert.
CB call. Shipwreck.
stripped down
cant stand IGNORANT b******ds
ok... im going to de solder the output pins but i want to replace them with some kind of psu type terminals.
any ideas of what i could use?
- cjay
- Call Sign: cjay
Depends, I'd try to solder a bus bar onto it.
thats what i thought cjay.... iv mannaged to get all the pos and neg terminals off so iv got a clear view of the board bottom ant top..
il take a pic tomorra
like this...
- cjay
- Call Sign: cjay
Nice.
If I could guarantee there are no tracks inside the board around those points, I'd think about exposing the copper on the board, drilling through the board and soldering a few machine screws to it, then you could bolt the bus bar to it, use a few shakeproof serrated washers.
- Call Sign: RDX64
You could scrape all the solder resist (green stuff) off so that you can solder bigger terminals onto it, a xacto type knife will do, or burnish it with a dremel - just be careful not to scrape the copper.
Even if it as a multi layer board I cannot for the life in me see anyone putting any tracks between the power pins on an other layer as there would be no need so I would be tempted to drill bigger holes - you can always inspect them with a magnifying glass afterwards to see if anything had been boogered up.
- cjay
- Call Sign: cjay
Neither can I, the only thing I can think is that there may be a sense connection but I agree that's unlikely
any suggestions as to what i can fit onto it?
- cjay
- Call Sign: cjay
What will the maximum current per device you'll be drawing from it?
I'd go with the bus bar and tap that to accept machine screws for fixing crimp eyelet/ring terminals as well as a few heavy duty binding posts.
TBH, no more that 25-30 amps in total lol
any links to the bus bar your referring to cjay?
- Call Sign: RDX64
Assuming that those pins are 0.1"/2.54mm then you could go with something like: http://www.toby.co.uk/content/catalogue ... ies=PCB-10 (this one is the wrong pitch, but Toby do samples).
I can't find a busbar with 2.54mm pitch that's solid bar, perhaps cjay knows of some.
You could go with spade terminals http://www.toby.co.uk/content/catalogue ... ategory=26 to get to big power connectors.
Or binding posts if you can find some big enough for the current.
http://www.digikey.co.uk/product-detail ... ND/5028401 are 36A
