Thanks. Anyone know for definite where I can find the Phantom powered on on the Bay?Kaos wrote:Battery.Irishman1127 wrote:Is yours phantom powered or battery Tim?
Straight into the FT950.
Brand new studio mics for under £20!!
- George EI7KO
- Call Sign: EI7KO
Re: Brand new studio mics for under £20!!
BLUE LED'S ARE BEST!!!!
FACEBALLS GROUP: https://www.facebook.com/groups/irishcustomradios
YOUTUBE CHANNEL: https://www.youtube.com/channel/UC4aXkT ... wszD8E68Dg
- Tigersaw
- Call Sign: GW6RRL
This is the one I bought from Amazon, definitely 48v phantom supply
http://www.amazon.co.uk/Floureon%C2%AE- ... %28Blue%29
- George EI7KO
- Call Sign: EI7KO
Want to find it on the Bay. I've money in PayPal I want to buy it with
- Black_Pirate
- Call Sign: 26TM034
Yes 13CT013 certainly sounding good....very good... I guess I need a change over lead...
I did think I could pass the audio thru the laptop into the radio via sound card and key it with the serial port....data connection etc etc...
Mine needs the power so not quite sure how to proceed...
May be thru the MD1 ptt base...! It's photom power supply that's the prob any ideas...
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- George EI7KO
- Call Sign: EI7KO
Or just use a mixer with a phantom supply. Less faffing about. Key it with a foot switch. Plus the mixer will give you an eq to play with
- prettypolly
- Call Sign: 26FB185
microphone 10.20.. spare xlr cable m to f cost £1.99.. mixer 34.99 ..ptt switch £1.00 is it working not yet but its on going..
- Toobad
- Call Sign: 26TM357
You could try the Yinger brand of BM-800. That requires phantom power and is available on the Bay of E for £12.87 delivered at the moment.Irishman1127 wrote:Anyone know for definite where I can find the Phantom powered on on the Bay?
http://www.ebay.co.uk/itm/New-Sound-Stu ... rmvSB=true
Just once I want someone to call me "Sir" without adding "you're making a scene."
- Kaos
Just off the radio with a friend in 68 Div and he has his NON BATTERY BM 800 look alike mic wired direct to his ICOM 735 WITHOUT the need for a phantom power supply.
He is going to send me (by email) his flowchart of how he has done this, so there might be hope for users out there with the NONE 1.5v ones.
And I will post it up here for info.
- George EI7KO
- Call Sign: EI7KO
It will work but not as it should as it wont be operating at line level as it should. Like using a CB powermic with no battery really. You wont get the best from it running it non powered like that...
- Toobad
IIRC, on a standard 8-pin Foster mic plug wired for Icom, the radio outputs +8V DC to Pin 2. That is how he is getting the mic to work on his Icom IC-735.
- gmham
- Call Sign: 108TM154
Need to find a uk supplier off the battery powered version, seems the ebay suppliers mentioned over on the CT forum have sold out, anyone else suggest a source ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Kaos
12 points goto Toobad.Toobad wrote:IIRC, on a standard 8-pin Foster mic plug wired for Icom, the radio outputs +8V DC to Pin 2. That is how he is getting the mic to work on his Icom IC-735.
There is the answer Mr 1127. Simples really.
These mics take owt from 1.5 to 48(?)v. So after talking to him at length last night he is indeed getting the full benefit from the mic as we played with the settings for a good 30 mins.
So all is not lost if one of your mic pins puts out +8v. Just make sure that the mic etc is wired the right way.
He also has an extensive range of other "Studio" mics.
- Toobad
The same goes for many Yaesu radios. Pin 2 of the mic socket on the radio's front panel supplies +5V DC. This is really the lowest voltage you can get away with for the phantom power variants and even then you will probably find you need to really crank your mic gain up far higher than usual to get satisfactory performance.
- George EI7KO
- Call Sign: EI7KO
That was my point. Full phantom voltage.... Full performance. It might be 42v but it's very low current
- Black_Pirate
So if I get a small Beringer type mixer from eBay £10 + quid that feeds the mic with maybe a tweak or two ....and a lead to the radio...yeasu £20 from eBay the ones with a ppt input on the side....
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
