Brand new studio mics for under £20!!
- Toobad
- Call Sign: 26TM357
For those of you who don't visit the CT Forums, I thought I'd just give a heads up to a thread I started over there. I was intrigued by the fact Ebay seems to be awash with Chinese branded condenser studio mics at ridiculously cheap prices. On the basis that things which appear too good to be true generally are, I decided it was worth a tickle to drop some coin to find out. I have done a China vs. USA comparison video pitting the young pretender against my megabucks HeilSound PR-40 dynamic mic. So if anybody here is looking to improve their audio on a shoestring budget, have a wander over to CT. My vid is in a public access sub-forum so you don't have to be a member and there is a link back to the original thread where you can find sourcing and other relevant info.
http://s3.zetaboards.com/copythat/topic/7738595/1/#new
Just once I want someone to call me "Sir" without adding "you're making a scene."
- astradyne
Re: Brand new studio mics for under £20!!
Link to eBay please
- Tigersaw
- Call Sign: GW6RRL
Thank you for the time and effort.
I'ver just listened to the recordings using only the cheese o matic tinny speaker on the work PC, so will try again later.
However, for the small moneys it sounds a brilliant investment
- Otter
- Call Sign: 26TM439
Just do an ebay search for Shengyue BM-800. Oh, OK, I'll do it for you <link>astradyne wrote:Link to eBay please
- Toobad
This is the exact one I bought for the comparison test. It currently weighs in at just over £19 delivered.
http://www.ebay.co.uk/itm/New-Condenser ... e#shpCntId
My 8 individual uncompressed audio clips can be downloaded from here for all you purists out there:
http://s3.zetaboards.com/copythat/singl ... &t=7738595
- Kaos
- ROTEL240
Thanks for the demo and the link but how hard or easy would these boom mics to wire into a superstar, cobra , optima etc thanks.
- Black_Pirate
- Call Sign: 26TM034
Yes I,d like to know the basics of wiring one of these up...
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- Toobad
Essentially the 3-pin XLR connector is wired with pins 1 and 3 connected to the shield and pin 2 carrying the mic audio. You will need to add a 2-wire PTT solution either by footswitch or separate handswitch. So you will end up with 4 wires going into the traditional Foster mic plug which connects to the CB.
- Tigersaw
- Call Sign: GW6RRL
Interesting the one you purchase and link to uses a 1.5 battery, whereas I find many of the same looking and equally numbered BM-800 ones on Amazon all require phantom power; in fact many reviews slate them for not being able to use with a laptop for instance.
Does it have a on/off switch associated with the battery, or do you have to take it out when not in use?
Looks good! Might be worth a punt at that money!
Build a man a fire, he'll be warm for a night. Set a man on fire and he'll be warm for the rest of his life.
- astradyne
I'd plug it directly into my Melos and use that to drive the audio. TX is via a PTT button or a footswitch.Black_Pirate wrote:Yes I,d like to know the basics of wiring one of these up...
They're amazingly cheap if bought from China. Less than £13 with free P&P if you have the patience to wait.
http://www.ebay.co.uk/itm/New-Sound-Stu ... 1481939177
- Toobad
Dave, as I said in the video, there are many brands but essentially only 2 variants. I specifically hunted down a Shengyue because it required onboard power. It just seemed a lot less faffing. Because it only requires 1.5V I think it is safe to assume it is powering an electret capsule. People buying the brands requiring phantom power of anything up to the 48V a mixer usually supplies will be getting what is probably viewed as a "true" condenser mic. Not that there is anything wrong with electret condenser mics, in fact 95% of Shure's range is now based around electret capsules.Tigersaw wrote:Interesting the one you purchase and link to uses a 1.5 battery, whereas I find many of the same looking and equally numbered BM-800 ones on Amazon all require phantom power; in fact many reviews slate them for not being able to use with a laptop for instance.
And no, it doesn't have an on/off switch, you would have to take the battery out for long term storage although I doubt it is beyond the collective knowledge of FADARS to rig up a switching solution
On a side note, I recorded the video using the Shengyue BM-800 plugged into the external mic socket of a Nikon D600 dSLR camera. I think you'll agree the recorded sound is even better on the voiceover than that recorded for the samples via my FT-DX3000.
- ROTEL240
Thanks again for the info lads worth looking into at that price.
- Tigersaw
- Call Sign: GW6RRL
I think you are mixing up Folkstone and FarehamToobad wrote: although I doubt it is beyond the collective knowledge of FADARS to rig up a switching solution
