anyone know the pinning for the Wouxun 950 programming cable?
(just a USB-serial with an RJ45 presentation... but what is the RJ pinout?)
73
Wouxun 950 progging cable
- Call Sign: 108SK05
- clayhead
Re: Wouxun 950 progging cable
Try this
https://au.groups.yahoo.com/neo/groups/KG-UV950P/files
Then look for KG-UV950P PINOUT.pdf
I hope it helps.
I hope it helps.
Hi, what is the RJ pinout?
without have account on yahoo
1 is to left, 8 is to right on rj45
- Marlin45
- Call Sign: 163CT266
No but you can buy the 920 one on Amazon for <£10 and it works the same as the MLS and Nevada 950 ones
http://www.amazon.co.uk/gp/product/B009 ... ge_o04_s00
'I'm a rider at the gates of dawn, and I take no prisoners' - Rik (The Young Ones - 1982)
- Mitch
- Call Sign: M1TCH
This is a pic of the pinouts from that Yahoo group (I'm a member)...sveifa wrote:Hi, what is the RJ pinout?
The perfect face for radio.
I have two wouxon handies did try to use a cable but had no luck at all in the end i binned the cable and disc and programed the rigs by hand using the keypad. From what i gather the only thing you cannot do is alpha tag your input frequency channels using the keypad so no loss really.
