- Stronty
Re: Homebrewing a Sirio Gainmaster using RG58 and 2.5mm wire
Just got to add, loving this thread.
Excellent work from PsiDoc and the pointers on wwdx and on here i'm thinking I might build one.
Credit to you all and happy New Year.
thanks for the offer psi but its ok, the curve was lobsided and higher than we wanted in frequency, we knew the stock red coax was not rg58 so a guesstimate for stub position was used, we have not tried any trimming as we got sidetracked into building a different antenna, im sure i had a sweep plot from the minivna i could have posted but i can't find it on my laptop.
W8JI
- Ashtec
- Call Sign: M6LTD
Some Excellent work from PsiDoc i must say!!!!!!!!!!!
- PsiDOC
- Call Sign: 163FKU
Cheers all.
Well, Last night I swapped the RG58 stub for one made of westflex 103 and I am please to say my calculations of 72cm for the W103 matching stub was right on the money and the antenna is exhibiting the same swr characteristics as it did with 55cm of Rg58. So the calculations I have posted I can safely say are valid and correct. You simply need to know the velocity factors of your coaxes to make the changes to the match feed point and the match stub length.
During testing the coax choke decided to spring apart. This was late last night and I was by this point tired so the antenna is now in my bag here in work awaiting me to find 5 mins to rewind it on some kind of former. Weather permitting it'll be back up on the test pole this evening.
Psi
Psi
*Proud owner of a Cornflake Packet Amateur License and registered instructor in the art of gaining said license*
Icom IC-756 Pro III
Yaesu FT100D.
President Washington
President Adams
Tait T2020 70mhz
Baofeng UV-5R 2m / 70cm
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
- MrWeetabix
- Admin
- Call Sign: 26TM175
few thoughts....wa10 wrote:
what would you call it? you always have a name for your creations.
Home master
Home Gain?
Gain Homer
Homer Master BB
GM BB Couger Thunderbird Fire Hawk Ultra 2000
- HomerBB
Home master
Home Gain?
Gain Homer
Homer Master BB
lmao
W8JI
- PsiDOC
- Call Sign: 163FKU
Another follow up for you all. After doing some research, using RG58 for the matching stub was a big no no.
According to some calculations I have done approx 40 - 45% of the power being fed into the antenna was being lost in the stub. Not good at all! By using westflex 103 as the stub these losses have been significantly reduced.
So please... DON'T USE RG58 FOR THE STUB! Westflex 103 can be bought for about £1.70 / Metre and it'll be the best £1.70 you'll spend if you make this antenna.
The antenna is back on the test pole and working well. Height above ground is 2.5 meters to the coax choke (9.5 to the tip) and approx 75m above sea level so quite low in both respects. Yesteday on 28mhz 7 solid contacts into the East US (Staten Island NY, Upstate Ny and Pennsylvania) were made with the lowest signal being a 5/7. Switching to the wire made very little difference to signal rx or reported tx back.
I think this one's a keeper!
Psi
Psi
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
- Black_Pirate
- Call Sign: 26TM034
is there a you-tube vid, of this? or if you make another can you do one...???
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- PsiDOC
- Call Sign: 163FKU
Does it really need a build video? There's only a bit more to it than making a simple coaxial dipole.
The measurements are all there in the picture.
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
- HomerBB
I will be doing this,
Thanks for posting it.
- PsiDOC
- Call Sign: 163FKU
Homer, to a man of your skills this is a lunch break antenna build. It's a simple antenna to make that performs well.HomerBB wrote:I will be doing this,
If you get any problems at all post here or PM me.
Have fun.
Psi
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
- HomerBB
Thank you, Sir. Will do.
- PsiDOC
- Call Sign: 163FKU
Not a problem bud.
PS: The only people that address me as Sir are the cops. That makes me nervous. Si will do nicely
Psi
Psi
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
Hello, newbie here.
I'm pretty new to this hobby and don't really have the theories behind all this in my head, but I've tried to read and learn as much as I can in these last few months.
So I began looking around this project and came up with some questions, if you don't mind.
Did I understand correctly, that you cut the coax at 218,5cm up from the choke, and connected the stub and the upper part of the coax to the lower part with a screw in terminal? (Forgive my lack of knowledge on the technical terms, English is not my native language and my skills are rusty.)
Due to the season all I have and can get at the moment is 6m telescopic fiberglass fishing pole to use as a mast. How would it affect the performance, if I wound the wire above the capacitor, or the whole thing for that matter, loosely around the pole to match its length better?
How much difference it would make if I used different than 2,5mm2 wire for the upper part?
Can I get this antenna to work as expected with just a cross needle swr/power meter?
As I've understood, some antennas need to be tuned where they are/will be installed to work properly, and others can be tuned (pretty much) anywhere and don't need any further adjustments if they are installed elsewhere. How does this antenna work? Set and forget? Or do I have to tune it up every time I change the location`?
I hope I didn't ask too many (dumb) questions. Thanks for the informational post, this just the kind of stuff I've been looking for, and thanks in advance.
