Cobra 148 GTL DX MK1 - Mic Audio Mod
- Phuture
Hi,
Is there a good mod to improve the Tx audio quality of the Cobra 148 GTL DX MK1? Compared to newer radios using the same mic (Astatic teardrop), mine sounds a bit thin at at the bass end and just not really a warm sound.
Re: Cobra 148 GTL DX MK1 - Mic Audio Mod
A lot can be improved.
PC879 or PB010?
PC879 or PB010?
- Otter
- Call Sign: 26TM439
Mk.1 is PC879.
Wide version:
C135, C128, C217 1uF non polar
Wider than stock, but not that much use MKT 330-470nF
- Phuture
Yes, I have the PC879 board - thanks Otter.
Thanks for replying to my post, Lemmy. So do you mean that to create a wider frequency response ("Wide version") I can replace C135, C128 and C127 with 1uF non-polar electrolytic caps? But, that using "MKT 330-470nF" caps would be better? Is MKT a manufacturer name and would these caps be ceramic or mylar?
Thanks!
Thanks!
MKT - mylar.
I use even 4.7uF in some radios.
Start with 470nF, difference to current ones will be huge.
For a try no need to replace, just add new, parallel to existing ones on the foil side.
- Phuture
So just to be crystal clear, attached is a close up of the PC-879 schematic around these caps. These are the ones you are suggesting I replace, right? (C128 circling corrected)
Different numbers on my schematic.
http://www.cbtricks.com/radios/cobra/14 ... /index.htm
Replace green if you want to open SSB as well.
- Phuture
Sorry, I circled C127 instead of C128 in my image (corrected). So the cap is actually C217, not C127 as you previously described? Thanks for clarifying.
217, fat fingers, corrected
- Phuture
Got it - thanks, Lemmy. I will experiment, as you say, and feed back. Looks promising!
- Phuture
Hi Lemmy,
I received the 470nF Mylar caps today. It looks like there are far fewer sellers selling values of these caps in between 470nF up to and including 1uF, but I will try the 470nF caps first to see how it goes.
Was the idea that I should replace all three of the existing caps (C128, C135 and C217) all at once or one at a time and then to test the audio quality?
Thanks!
Thanks!
All of them.
Each one of those is a bottleneck.
- Phuture
Got it - thanks! Will report result tomorrow.
Are you saying that these new 470nF caps need to be added in parallel on the solder side , or do they replace the original part ?
