Intek tornado 34s cb radio follow on from lcl2740
- Call Sign: g4sbx
Hi guys your response to my project has been phenomenal ....the lcl 2740 has now been fully aligned and its the best i can get it....
ive now realized looking through my old gear...ive found a Intek tornado 34s am fm ssb radio....this uses the same pll mc145106
so i thought why waste anymore time on the lcl2740 when this rig has more features....this all started in 2017 when i posted about my late fathers rig he bought back from the USA a montgomery ward 719....this rig turned out to be too complicated to convert to 10 metres....hence i moved on to this intek tornado...ive had a hell alot of help from Ibcomms sue down under....so this project is to be restarted...ive got find a 15.360 mhz crystal...
thats where we left it...
the only problem i can see is why it only goes to ch 34 or this may be normal....its shown on the net as being 40chs...im well confused...
the other thing before any work can be done...is to sort out the strange freq readouts...
so more to follow on this....
cheers all
paul
g4sbx
cheers all
paul
g4sbx
- Call Sign: g4sbx
Re: Intek tornado 34s cb radio follow on from lcl2740
Hi all..got the intek tornado on bench....just confirmed strange chs
ch 34 = 26.955
ch 20 = 27.205
ch 1 = 26.965
also above rotary ch switch is a connector i notice a green wire has been cut ?
or is this normal...please see enclosed photo
ok gonna start to check underside of board...will report as I go on...
thanks
Paul
ch 34 = 26.955
ch 20 = 27.205
ch 1 = 26.965
thanks
Paul
- Call Sign: g4sbx
Hi all..well checked the pcb under the mc145 i cant see any damage or bad connections can the pll itself be faulty?
so stuck at mo...
more if i find anymore out..
thanks
guys
paul
so stuck at mo...
thanks
guys
paul
Channel 20 is correct (27.205) so measure frequency while going up one channel at a time until to find where it breaks. Once you find which one, post the PLL program pin voltages here on the last "good" channel and for the one above it that's incorrect. The PLL could be bad, but that's normally only seen where people have been playing in that section for channel mods, they rarely fail on their own. More likely a wiring or broken connection issue, measurements will reveal all...
- 14CS06
Hello
Intek Tornado 34s is approved for 34 channels in italy
Switch 34CH instead of 40
The board does not have mc4008 adders
What is the reference of the PCB EPT00???
- Call Sign: g4sbx
Hi Claude
the ept is
EPT-360012B
Hope that helps..
ok thanks ibcomms and others once agn you all come sailing through...regards the tests i will report back tomorrow...
thanks in advance
paul
the ept is
EPT-360012B
Hope that helps..
thanks in advance
paul
- Call Sign: g4sbx
Hi Ibcomms
one thing not sure what you mean by < PLL program pin voltages > can you explain a bit more..
thanks
Paul
thanks
Paul
- 14CS06
- Call Sign: g4sbx
thanks Claude
what does this board do....my italian not good?
cheers
paul
cheers
paul
- 14CS06
- Call Sign: g4sbx
many thanks claude....once i get it working i may well get one these boards...hope its easy to fit...guess chs then sw in banks some how..
thanks
seems ive got lot tests to do morrow...just waiting to hear back about <PLL program pin voltages>
oh well more tomorrow..
paul bon soir
thanks
paul bon soir
- Call Sign: g4sbx
Hi Ibcomms and other interested parties....as requested full truth listings as requsted.
We decided to perform a full test of all the channels, on this device a total of 34.
From channels 26 and up, we have measured a shift of 390KHZ lower then expected, the following is the table we produced from the PLL's P register.
Last good was ch.23
1 is approx 8.72V, 0 is 0.14v(We are reading from pin 17 to to pin 9 on this binary table)
* CH23 000 111 100
? CH24 111 011 100 (+10KHZ 27.245mhz?)
? CH25 100 111 100 (+20KHZ 27.265mhz?)
? CH26 010 010 100 (-390KHZ 26.875mhz?)
? CH27 110 010 100 (-390KHZ 26.885mhz?)
? CH28 001 010 100 (-390KHZ 26.895mhz?)
? CH29 101 010 100 (-390KHZ 26.905mhz?)
? CH30 011 010 100 (-390KHZ 26.915mhz?)
? CH31 111 010 100 (-390KHZ 26.925mhz?)
? CH32 000 110 100 (-390KHZ 26.935mhz?)
? CH33 100 110 100 (-390KHZ 26.945mhz?)
? CH34 010 110 100 (-390KHZ 26.955mhz?)
Last good was ch.23
* CH23 000 111 100
From that it looks like it's got an incorrect switch fitted - maybe someone replaced a faulty switch in years gone past with one from another set, assuming that all switches that look the same are the same? A bit of history on the set might help - has the radio ever worked correctly when you owned it, and is there any evidence of change such as altered wiring or fresh soldering in that area?
If it is the wrong switch, you have two options - either obtain a correct one from a junker, or fit an EPROM (or in 2021, a microcontroller!) programmed to match the switch you have to the PLL in the radio.
- Alucard
- Call Sign: TW4T
Does this only go up to channel 34?
According to Claude's info the channel range is 26.875-27.265 which is messed up anyway, well compared to everyone else.
What is the frequency on channel one? Over.
- Call Sign: g4sbx
hi alucard agn yes ch1 is 26.965 MHz and yes it only goes to ch 34...
but seems I've run out of options just been looking on internet....those ch selectors are very rare....
thanks
paul
thanks
paul
