Advice on another forum suggests a Toko 119AC30099R might be a good alternative, so I've ordered one...
See if it works when it arrives!
Possible Repair - PCMA001S - Variable Inductor Coil?
- Call Sign: 26TM2714
Re: Possible Repair - PCMA001S - Variable Inductor Coil?
WANTED
Galaxy Pluto, 2100, DX88HL, President Ronald (Or Equivalent)
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
They're simple to repair Peter . Just remove the metal can , and carefully unwrap the 475 meters of 0.00001mm wire , looking for any breaks and damage on the way . One you've found the break , then resolder it with a 150W soldering iron . Re-wrap the wire , replace metal cap , and job done
Paul,cb4ever104 wrote: ↑15 May 2021, 09:40 They're simple to repair Peter . Just remove the metal can , and carefully unwrap the 475 meters of 0.00001mm wire , looking for any breaks and damage on the way . One you've found the break , then resolder it with a 150W soldering iron . Re-wrap the wire , replace metal cap , and job done
Thats the sort of thing I would have a go at doing, or at least count the turns and try replacing with new!
But, T7 wasn't there when I got it... thats the reason I need one.
WANTED
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
Rather you than me m8 Hopefully you'll find a replacement .
S.
