Cobra 148GTL power mic w/6 wires (no model #)
- Call Sign: Redbandit07
Hello, has anyone any info on a vintage "80s or 90's" Cobra power mic, which I've seen regarded as Cobra 148GTL? It has 6 wires, shield, black, red, yellow white and green. The odd thing is, there is no model number on it. I bought it from an estate sale. I am thinking of wiring for a SS 3900G. Just wondering if the 4 pin wiring will change (which I suppose). See photos
Re: Cobra 148GTL power mic w/6 wires (no model #)
I remember them but i also remember the same mike with different names.
Not sure but i don't remember them being up to much.
Ant the wiring just go along with it as the 4 pin forget the cut off wire and id the black with the braid ?.
The problem I am having, is that I see a lot of the other wirings show a blue wire and no green. And so I am trying to figure out if the blue wire does the same job as the green, except its a different color.
same thing as the grey OPEK, euro-cb, pan dm437, i don't think they all used the same wiring colours,
from the pics it looks like white has the braid wrapped around it so that's audio & should be on pin 2 for uniden wiring
W8JI
Thanks for the reply. The braide is together with black. The order it was in when I got it are the following:
1- Black/shield, 2- Red, 3- White, 4- Green.. The other issue I'm concerned with is, since it's a power mic, will the wiring sequence have any particulars in the color of wires.
I see there's vague variables..
I know naff-all about mic' wiring but I do know that if I need to change a 4-pin Cybernet-wired mic' to 4-pin Uniden, then with the mic' plug "indent" at either the top or bottom, top left swaps with bottom left and top right swaps with bottom right. You could try that first, but always make a note of where the wires are at the moment.
Black and screen/earth/braid, nearly always go together on a power mic' as a rule.
That's about the total amount of my knowledge!
Thanks,, when you say, Black and screen /earth and braide, what exactly are those? Black and braide I understand,, what do you mean by screen and earth..?
Jp
Jp
Braid, screen and earth are known terms for the same
bare, unshielded copper wire. Whether or not it's 100% correct I'm not sure
- 14CS06
Hello
Cobra CA-75
http://www.cbtricks.com/mic_manuals/cob ... matic.html
Cobra HG-M75
Cobra CA71B
http://www.cbtricks.com/mic_manuals/cob ... 75_fix.pdf
Claude
Cobra CA-75
Cobra HG-M75
Cobra CA71B
Claude
Hello Claude, wow this is far out, you found the model number for this Cobra mic, CA71b.. The mic itself doesn't have it etched anywhere, thanks alot. I haven't figured out the wiring pin sequence, but I'll keep at it. I didn't know you had posted this, it just doesn't pop up in an email like with other Cb thread. Thx again Claude.
Wishing you and your family and everyone here a Happy and blessed Thanksgiving..
What's one of those thanksgiving things?
We don't celebrate that over here. Saying that, if it's a good excuse for more sprouts and turkey, then I'm up for it!
Ohh, my apologies, I had no idea. Well, then I hope you enjoy the sprouts and turkey. If you don't mind me asking, where IS over there? 73s..
- 14CS06
Hello
From https://www.britannica.com/topic/Thanksgiving-Day
Thanksgiving Day, annual national holiday in the United States and Canada celebrating the harvest and other blessings of the past year. Americans generally believe that their Thanksgiving is modeled on a 1621 harvest feast shared by the English colonists (Pilgrims) of Plymouth and the Wampanoag people. The American holiday is particularly rich in legend and symbolism, and the traditional fare of the Thanksgiving meal typically includes turkey, bread stuffing, potatoes, cranberries, and pumpkin pie. With respect to vehicular travel, the holiday is often the busiest of the year, as family members gather with one another. Thanksgiving Day is celebrated on Thursday, November 26, 2020.
Claude
Claude
- 14CS06
Wow Claude, you always seem to out-do yourself..hehe. Good history lesson.. Thx. And, this mic, looks just like mine but has different color and name. If its wiring is compatible to the cobra, perhaps it will work out. I'll try it. Thanks so very much Claude. 73s.
