Page 1 of 1
SWR METER CB ( 27 Mhz ) SCHEMATIC MADE BY YOU
Posted: 14 Jan 2020, 18:06
by rooth
I didn't see a topic on this forum.
Have you made a diagram for a well-functioning CB radio SWR meter?
I am referring to an original scheme .
Re: SWR METER CB ( 27 Mhz ) SCHEMATIC MADE BY YOU
Posted: 14 Jan 2020, 18:40
by ch25
I rather modified existing ones since they are crap.
Posted: 14 Jan 2020, 19:09
by rooth
I have a Zetagi Mod 203W 3-200 MHz that is not working properly.
After adjusting the head of the scale to 10, when I switch on the reflector, it remains to 10, it does not move at all. I checked everything, I did not cut off. The diodes are ok, the cable is the same ... I have no idea what he has .
It would help a picture from the inside if someone has the model.
That's what it looks like to me .
Posted: 14 Jan 2020, 19:58
by ch25
No clue. Faulty switch?
Posted: 19 May 2020, 15:56
by Dave C
rooth wrote: ↑14 Jan 2020, 19:09
I have just purchased a brand new Zetagi, it looks like the same one as yours, I had extremely high SWR's despite all new cable and connectors, I eventually traced the fault to a faulty soldered connection on the centre pin of the SO239 where it meets the board...
I'd certainly go over the connections if I were you Sir
Posted: 19 May 2020, 17:34
by The Collector
I confess to knowing nothing about electronics, cb in general or indeed meters, but does the solder connection on the left terminal (as viewed) on the meter look like it's possibly got a hairline crack around the joint when zoomed in...or is it just my eyesight?
Posted: 19 May 2020, 18:18
by Stronty
ch25 wrote: ↑14 Jan 2020, 18:40
What would you modify on a 203w if at all?
So internal pic of an old 203w that seems to give a reasonable representation of what its intended purpose is (lets face it its no BIrd 43/ Rigexpert). not sure that helps you but at least you have a something to look at :-).
Posted: 19 May 2020, 21:07
by ch25
Get 100 ohm/ proper wattage resistor, that way you could calibrate it.
Posted: 20 May 2020, 00:05
by Stronty
ch25 wrote: ↑19 May 2020, 21:07
Thanks for the hint, so something along the lines of what is described here >
http://www.bmarc.org/tech-corner/checki ... swr-meter/
Posted: 20 May 2020, 00:16
by NightProwler
Thats tomorrow project for me then
