Hi everyone!
I'm brand new into CB and have purchased a 2nd hand delta Lt 318 and want to have it in the car and was wondering if you guys could recommend a good antenna and mount for use in the car.?
I have an Audi A4 saloon
Much appreciated guys
CB car antenna
Re: CB car antenna
A Sirio 4000 and a Sirio 145mm magmount base,yes it will cost a bit more than others,but they tx/rx very well.
27.555 Usb
27.555 Usb
- New User
- Call Sign: m6ceb
Re: CB car antenna
Thanks so much appreciate the advise thats what ill go for
Re: CB car antenna
If you go round corners fast, get the slightly larger and more powerful Sirio 165mm magnet to help keep that 2m long aerial stuck on well
- andrew013
- Call Sign: 26AT013
Re: CB car antenna
Sirio 4000 and a Sirio 145mm magmount base, is a good choice and no need for the larger mag base tbh as 98% of the ariel is just a whip if you wanted a smaller ariel just get the 3000 instead
Re: CB car antenna
The 145mm will be fine for a 4000,especially on the boot of an A4 saloon m6cebThe Collector wrote: ↑11 Jan 2020, 12:36 If you go round corners fast, get the slightly larger and more powerful Sirio 165mm magnet to help keep that 2m long aerial stuck on well
And if you go round corners on 2 wheels in the A4 get a triple magmount base
27.555 Usb
27.555 Usb
Re: CB car antenna
Should be fine on FWD, I was thinking back to losing magmounts whilst snaking sideways in my Mk1 Escort lol.
- Call Sign: 45
Re: CB car antenna
Sirio 4000 , can't remember which model it is but one type of the sirio 4000 has no grub screw ajustment for the whip length and you have to either cut whip or suck it and see.
So I always recommend the grub screw model personally.
