President Jackson without final
cb4ever104
Re: President Jackson without final
Post by cb4ever104 »
rocketry23 wrote: 06 Jan 2020, 19:21 It is hard to find even a 2SC1969 in Hungary.... :( Maybe if you can link me a trusted seller on ebay?
2SC1969 here
https://www.ebay.co.uk/itm/272488057198
An MRF477 might be a bit harder . There's a couple of originals on Ebay , but they're £40+ , which is too expensive . If I were you I'd just repair the driver and final stage and stick in a Eleflow CB-20 .
rocketry23
Call Sign: 109HA161
Post by rocketry23 »
cb4ever104 wrote: 06 Jan 2020, 20:06
2SC1969 here
Thanks for link but they do not ship to my country.. {bnghd}
cb4ever104
They ship to Europe, and Hungary is in Europe. Send them an email and ask them.
rocketry23
Call Sign: 109HA161
I'll give it a try! Thanks! :)
Edd200sx
Call Sign: M6KMX
Post by Edd200sx »
4a0026aleks
Call Sign: 4a0026
Post by 4a0026aleks »
in Hungary it is easier to find a Soviet transistor kt 920 V
4a0026aleks
Call Sign: 4a0026
please read the service manual for the device.... what transistors are in presidents ....2sc1969 or 2sc2166 ARE not SUITABLE !! by gain and mode....when installing KT920V mechanical alteration! when you install the other transistors...- designers put 2sc1969 (2sc2166) in parallel - not just like that
Call Sign: Lemmy
Post by ch25 »
If you want use mrf455 or similar just mount transistor on back and connect it with wires. Put 1n4148 as bias diode.
Set bias with PR and job done.
rocketry23
Call Sign: 109HA161
ch25 wrote: 07 Jan 2020, 15:24 If you want use mrf455 or similar just mount transistor on back and connect it with wires. Put 1n4148 as bias diode.
Ok I wired in my SD1487. I had to replace VR9 because it was faulty.
It is interesting, there is 7mA bias current even the radio is switched off!
I set 150mA bias on TX.
There is 10W AM/FM output, but i cannot set SSB power above 20W. I even tried to adjust the related coils L43 42 41 33 30 as written in manual.
Thank you all for your help!
Call Sign: Lemmy
Post by ch25 »
rocketry23 wrote: 13 Jan 2020, 21:00It is interesting, there is 7mA bias current even the radio is switched off!
So there is something really weird with your radio :)
rocketry23
Call Sign: 109HA161
ch25 wrote: 13 Jan 2020, 21:58 So there is something really weird with your radio :)
Haha, yeah its a weird radio :lol:
Or maybe I'm doing something wrong.
But at least I learnd lot of things thanks to you!
cb4ever104
Is the base on your SD1487 connected to the chassis ?
rocketry23
Call Sign: 109HA161
cb4ever104 wrote: 14 Jan 2020, 15:12 Is the base on your SD1487 connected to the chassis ?
No it is not connected to chassis.
cb4ever104
rocketry23 wrote: 15 Jan 2020, 07:38
OK . It was difficult to see in the photo .
13EL121
Call Sign: 13DA121
Post by 13EL121 »
I did a Mosfet conversion at two President Jackson with very good results. Easyly 8-10 watts AM/FM and over 20w SSB PEP clean audio with two Fqp13n10 for driver and final. You will need to swap some more parts, but they are cheap. But it's not a job for starters.
