Astatic 1104C - Repair & Overhaul
Re: Astatic 1104C - Repair & Overhaul
Good luck with the sliders fitting, I don't know how people manage to lose them unless they are weak & break off.
W8JI
- 13EL121
- Call Sign: 13DA121
They break off easily after all the years. Old plastic material.
- 13EL121
... They fit very well.
I need the same pair of plastic/sliders for my microphones, I can not find it them the US
I have 3 in my collection and 1 just like yours in the picture,1 red and another in black
Tecnicoloco1
Tecnicoloco1
- 13EL121
I will talk to the printer if he can make some black sliders. But they can be spray colored of course. For best results they can be grinded with fine sandpaper before painting.
- Stronty
Evening Ralf, nice work on the 3D printer. I'm still looking for 1 of those, don't care about colour.
let me know if you can help.
thanks again
thanks again
- 13EL121
Hi Stronty, check your email account.
- Stronty
Ralph, thanks for getting in touch. You're a Gent.
- Stronty
Well my thanks go out to Ralf and the return of a favour more than 7 years old.
I needed a single slider due to one missing when purchased. Ralf came through with a lovely pair of sliders, though I have only replaced the one I require at the moment.
It fits well, I let the heat of the sun at it for 10 mins and just pressed it on as you do with the top case of the Mic when reassembling.
Looks the part and works as the part.
- KlondikeMike
- Call Sign: 9WR2000
Good job. I have contemplated this for awhile but lacked the resources. I will need a few when you are ready to ship.
- 13EL121
Next batch comes middle of August after my holidays.
I’ve just acquired a mic same as this today.
Sliders are not broken!
I do have to strip it down though to take apart and
Grease the sliders etc
DELETE MY ACCOUNT
- Stronty
Out of interest, what do people use to grease those sliders?
I have used silicon grease over the years, not spray.
