rocketry23 wrote: ↑08 Feb 2020, 14:22
slamjam wrote: ↑18 Sep 2013, 22:57
Remove J36 and J37, link wires from the holes to a switch as per picture. Hey presto 5kc jump. I think from memory it goes +5 on USB and -5 on LSB hope that helps.
Hi!
Can somebody explain me that switch? It's not clear for me what needs to be connected with that switch
I ended up trying this some time ago and unfortunately this method doesn't work, It isnt + or - 5kc, It may be close but not spot on and it cannot be aligned for 0 either or 5 will go off, All this does is swap the USB/LSB inductors around making the two modes go "off frequency" and does not get you zeros.
The easiest way to get zeros on a PC-999 is too get a Mauer module and that will get you exactly +5kc and also UK
Or the fiddliest way is to replace the three 15.4525 inductors for LB209s, [From a scrap PB010 or PC-879, I think LSB already uses an LB209] and the veractor [from a scrap PC-879] and that will get coarse on a black grant [fine and coarse] to do pretty much the same slide as a PB010 and the 15.4525 doesnt have to be replaced for a UNI 15.4500 either, There may be too much slide so a resistor from the wiper coarse trace to ground may be needed, This can vary in value to reduce the amount of slide, Too much slide and radio will start to drift, It could be done the same for the 15.0025 [Low band] as well but who uses zeros on Low ?
