New expansion - uPD2824 chassis
cb4ever104
Re: New expansion - uPD2824 chassis
Post by cb4ever104 »
lbcomms wrote: 20 Nov 2021, 11:40 CLK0 and CLK1 should show about 2 to 3 volts peak to peak. CLK0 should be exactly 25 MHz, CLK1 should be in the 15.3 to 15.8 range. The radio can't work without the 15 MHz signal
Hi Sue .
Can you just confirm something . Looking at your photo your main "CLK1" output which goes the vacant pin on L13 is actually connected to GND on my radio . Your pcb looks to be the same as mine , but maybe the solder side layout is different on the Realistic ? My main connection for L13 is on the bottom pin . Not the top . Silly error from me , but I was desoldering tonnes of stuff at the time , and I missed it . I'll need to remove that board to rewire it .
Paul
lbcomms
Post by lbcomms »
There may be a slight pinout difference from mine (a Realistic TRC-451), follow the trace, it connects to the capacitor that goes to the base of the downmix transistor:
Hopefully grounding it didn't kill the 5351 chip. I'd leave it off and verify you have a 15MHz signal at CLK1 first...
cb4ever104
lbcomms wrote: 20 Nov 2021, 12:14 Hopefully grounding it didn't kill the 5351 chip.
My schematic is different from yours . Think I need to remove C72 as well
lbcomms
Post by lbcomms »
cb4ever104 wrote: 20 Nov 2021, 13:22 My schematic is different from yours . Think I need to remove C72 as well
Yes, that's very different to the 2824 radios we have here. You will need to remove C72 in that circuit.
That also explains why the radio still transmitted and received, albeit on the wrong frequency.
The PLL divides the 10.240 by 2 and outputs the result to pin 10. It's a square wave, so it's also full of odd harmonics. The inductor and two capacitors are a bandpass tuned to 15MHz, so they let through the third harmonic (15.360 MHz) and it is then mixed at the transistor with the VCO to produce the downmix signal needed to lock the loop.
26.965 - 10.695 = 16.270, and 16.270 - 15.360 = 0.91 MHz, exactly whats needed to lock the loop on FCC channel 1. The original SSB offset inductors and clarifier also connect to the 10.24 to change things a bit for SSB use.
BUT: when you remove C72 and there is no output from the 5351, there will be no downmix signal at all and the radio will quit.
Find why there is no output from the 5351 board before going any further. It's either faulty / damaged, or not wired correctly. Disconnect the output from CLK1 and measure with a scope and frequency counter. You should have a 3V P-P waveform at CLK1 at all times around 15MHz, and 25MHz at CLK0 when it's enabled at the PC app.
Once you have the waveform on the 5351 board, remove C72 and connect CLK1 to the L13 hole that goes to C73. The radio should come to life.
Once that's done, use the PC app to configure the 25MHz, offsets, and clarifier.
cb4ever104
Removed C72 and rewired L13 Sue . I now have 25Mhz on CLK0 , and a fixed 15.360 on CLK1. However , I still have a few issues as my pll now isn't locked , and the radio is stuck on 27.5 something . My 15.360 is connected to one end of C73 , so I'm not sure what the problem is . Might need to check TR19 . I'll need to go through it to see what's going on . I'll post back when I can .
cb4ever104
OK . I'm getting there . Think my pll was knocked out at some point during the last post and never came back . Anyway ...
Powered on and everything is looking good . I still have to set my SSB offsets , but the radio is working fine on both the MID and HI bands . I need to hard wire in the HI , +10khz and +5khz and tidy things up .
Thanks for your help with this Sue . I'll post a photo or 2 when I'm finished .
Paul
lbcomms
Post by lbcomms »
You should have a healthy (1V P-P or better) signal at TP4 / Pin 22 of the uPD2824 chip, ranging from 0.91 MHz on channel 1 to 1.35 MHz on channel 40.
If the radio was hovering at a random frequency then that signal was missing for some reason. There's not much to that circuit to troubleshoot, a transistor and some passives. Anyway, sounds like it came to life. Possibly a stray fleck of solder or other debris?
You're nearly there with this one...
cb4ever104
lbcomms wrote: 21 Nov 2021, 18:25 You should have a healthy (1V P-P or better) signal at TP4 / Pin 22 of the uPD2824 chip, ranging from 0.91 MHz on channel 1 to 1.35 MHz on channel 40.
To be honest I haven't actually checked its VCO range yet . I was just really concentrating on getting those 2 boards working. Saying that I might give it a check before I start to finalize things as I think most of the VCO section is under my oscillator board , and it might be a pain to access that area if I need to change or add a cap.
lbcomms
Post by lbcomms »
You shouldn't need to change any components of the VCO if you are only adding one more block of 40, at most you'll need to tweak the VCO inductor (L14 from memory) a fraction of a turn to get it to lock on the highest channels.
cb4ever104
I love radio :D
S.
lbcomms
Post by lbcomms »
Yep, been there done that. Track cutting and wire linking to repurpose useless switches (like PA and instant channel 9) for channel control always was a bit of a pain on that model...
cb4ever104
It's actually easier on this one than on the Cobra 146 GTL . That has a front pcb mounted vertically and the switches and controls soldered to it. I gave up with that one. I was thinking about using magnets and some reed switches with it. Or fit an external box with a few switches on it. To be honest I do enjoy this part when you need to break it all down and rebuild it.
lbcomms
Post by lbcomms »
Yep, know that one, that was actually one of the radios converted later. Pots and even the mic socket from memory mounted onto that front panel board :twisted:
cb4ever104
Sorting out these 4 switches is actually taking longer than the nano install ! :lol:
Anyway. They're done now.
Now got some reassemble work to do before I go though the SSB/Clarifier setup again.
S.
lbcomms
Post by lbcomms »
I usually do that part first (after doing any repairs needed to get the radio working perfectly as stock), then do the main board mods second.
Hopefully you'll lots of use out of that radio after putting in all that effort to mod it...
