Solder advice
- Call Sign: 26AT239
Re: Solder advice
You need to use a high lead content solder, don’t use anything else because it does not flow well and is less conductive and more prone to causing dry joints. And use flux.
- Mudslinger
Re: Solder advice
- Call Sign: AMC45
Re: Solder advice
I’ll have a spare 0.7mm 500g CYNEL Tin Lead 60/40 Flux
Bought 1.5kg as it was cheaper than 1kg
- cb4ever104
Re: Solder advice
Where'd you buy it from ?
- Call Sign: AMC45
Re: Solder advice
Poland. Have to buy a fair bit to get free postage.
https://www.tduoyin.com/07mm-500g-solde ... 265108.htm
- cb4ever104
Re: Solder advice
Ok. Cheers
- Call Sign: AMC45
Re: Solder advice
I added the link forgot earlier
- cb4ever104
Re: Solder advice
Saw that . Cheers . I'll buy 3 when I get the refund from the other stuff that I bought
- Call Sign: AMC45
Re: Solder advice
I just hit PayPal refund. They either went bust or it was a scam
Pain in the arse
Pain in the arse
- bigpimp347
Re: Solder advice
buying real solder isn't like popping to the shops,
you need to search for it, around £15 for a 400g 500g roll up to £30..
if it's less than £10 for 500g it's probably crap..
BUT if you but some they claim is 60/40 rosin cored lead solder and it still doesn't flow use a bit of plumber flux before you use it,
i have a roll of crap i use with plumbers flux for wires and loads of big soldering, i just clean up after using IPA.
i use Multicore 60/40 tin lead solder for proper stuff like IC's and components..
- cb4ever104
Re: Solder advice
I just bought this one
https://www.ebay.co.uk/itm/153884455199
1Kg , so It should see me through to my arrival at the gates of heaven
edit : Changed link . It was the 0.7mm one I bought . Not the 1mm
- Call Sign: Lemmy
Re: Solder advice
Good choice.
- The Collector
Re: Solder advice
If they weren't already welded, you could easily SOLDER the gates of heaven with that roll!cb4ever104 wrote: ↑13 Jan 2021, 17:50 I just bought this one
https://www.ebay.co.uk/itm/153884447239
1Kg , so It should see me through to my arrival at the gates of heaven![]()
- cb4ever104
Re: Solder advice
Or maybe just use it as a door stopThe Collector wrote: ↑13 Jan 2021, 20:28 If they weren't already welded, you could easily SOLDER the gates of heaven with that roll!![]()
